13 Pages «<34567>»
Delboy271155 Sots Options
#81 Posted : 21 May 2013 10:34:29
Captain David wrote:
It's coming along nicely, Derek. I hope my planking will be as good.
Hi Cap`n,BigGrin
Thanks for the nice comments, I had a few moments in the planking where things took a bit of a wobble, but, took note of advise from the more experienced builders and took it slowly slowly and I think it was advise well listened to.
Good luck with your ongoing build.
claret
#82 Posted : 21 May 2013 11:56:39
Hi Derek,
Planking looking good. cutting canon ports next!!!
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
#83 Posted : 21 May 2013 14:32:36
claret wrote:
Hi Derek,
Claret
Hi Claret,BigGrin
Thanks for looking in,the planking looked like a devil of a job when I first took it on, but, the gun port cutting is scaring the living c**p out of me. Cutting into all that hard work Confused and hoping it`s all in the right place Crying .
Well looks like another session of mark it, check it, check it again and again then take the bull by the horns,BigGrin
NMBROOK
#84 Posted : 21 May 2013 16:15:00
Looking good DelBigGrin BigGrin .Glad to see the repair is holding up.
Kind regards Nigel
#85 Posted : 21 May 2013 16:18:49
Kind regards Nigel
Hi Nigel,BigGrin
Thanks for taking a look,the repair seems stronger than the rest,just hoping when it comes to cutting the gun ports I don`t need to do any more repairs.LOL LOL
#86 Posted : 22 May 2013 16:27:41
Hi all,BigGrin
Had a good day on the the planking todayCool . The results are that I have reached the end of planking for issue 33. Still have the infill and trimming bits to do but happy with results to date.
Here`s the pics below, comments and advise welcome as usual.
NMBROOK
#87 Posted : 22 May 2013 17:30:49
Coming along well DelBigGrin BigGrin I have a hard rubber double length sanding block I got from a car bodyshop suppliers.They are fairly inexpensive and do help in smoothing out any high and low spots,I find a normal block a little short to get true lines without alot of constant checking.I also used a piece of garden hose with the paper wrapped around it for the awkward shapes at the stern.
Kind regards Nigel
#88 Posted : 22 May 2013 17:39:33
Kind regards Nigel
Hi Nigel,BigGrin
Thanks for looking in and some good tips WTG.
#89 Posted : 22 May 2013 19:51:41
BigGrin Nice work on the planking lovely jubley BigGrin Rgd Martyn
der Gohfelder
#90 Posted : 22 May 2013 19:53:35
Hi!
Well done, go on this way ThumpUp
Regards, Bernd
#91 Posted : 22 May 2013 22:12:07
Its looking good Derek, nearly at the top and then the sanding phase.... think she will sand down very nicely indeed... Cool Cool
Hans
#92 Posted : 23 May 2013 08:49:38
Good job there Derek, impressive.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
#93 Posted : 23 May 2013 19:13:26
Kind regards Nigel
Hi Nigel,BigGrin
Thanks for looking in and the sanding tips,
#94 Posted : 23 May 2013 19:15:00
Cheers Martyn,BigGrin
Thanks for looking in.
#95 Posted : 23 May 2013 19:16:29
der Gohfelder wrote:
Hi!
Regards, Bernd
Cheers Bernd,BigGrin
#96 Posted : 23 May 2013 19:19:33
Hi Alan BigGrin
Thanks for looking in,have had a little look for the highs and lows and it does look pretty good for a first attempt.Bit more at the stern due to the twists and turns but should be Ok.
#97 Posted : 23 May 2013 19:20:44
Hi Hans,BigGrin
Thanks for looking and and the nice comments.
#98 Posted : 17 June 2013 21:35:32
Hi All,BigGrin BigGrin
Just a very short update, with thanks to those who assisted with my question on the final upper planking session.
Problem now understood so there`s a pic one side completed below.
Next update may be delayed, I`ve got nearly 100 babies to look after.
Sorry baby Angel fish, missed that bit out.
LOL LOL LOL LOL LOL LOL LOL LOL LOL LOL LOL
#99 Posted : 17 June 2013 23:16:29
Looking good Derek and you did the right thing by adding the extra plank...Cool Cool .. As long as you are above the ribs then you will be fine... Well done m8....BigGrin BigGrin
NMBROOK
#100 Posted : 17 June 2013 23:33:57
WTG DelBigGrin BigGrin BigGrin .As Alan said will sand down well,but don't forget about the hull profile post.
Kind Regards Nigel
13 Pages «<34567>»
This page was generated in 0.526 seconds.
