Fuel filters and exhaust.- Options
Nightrider
#1 Posted : 15 May 2013 05:57:58
Another quick-fire question...
Would it be worth while attaching a fuel filter to the fuel intake ?
And... Where is the exhaust located on the car? Is it at the rear of the vechile ?
I've tried looking at the images in the mag, but just can't seem to see it.
#2 Posted : 15 May 2013 09:00:22
Its always a good idea to fit a fuel filter into the fuel line.
The exhaust manifold is at the rear of the engine, which exits downwards into a muffler assembly and then a tailpipe exits to the rear.
#3 Posted : 15 May 2013 10:59:49
Also 'After Run' oil is worth buying.
The Methanol content within nitro fuel is 'hygroscopic' and therefore attracts moisture from the atmosphere, where fuel deposits that remain within the engine after the days running (or model storage) may cause internal corrosion.
Treating the engine with after run oil will protect the internals of the engine from corrosion during storage.
This also applies to the Hummer nitro engine.
willie
#4 Posted : 15 May 2013 13:11:08
a good squirt of wd 40 in the cab and a few flick over of the engine[ dont put the starter battery on the engine or it could start]can help with the water as wd40 dispence the residue and anny water
#5 Posted : 15 May 2013 15:38:48
I used rubbing alcohol in mine, cheap as chips and dries with no residue.BigGrin BigGrin
Nightrider
#6 Posted : 16 May 2013 10:34:16
Thanks for the info.
The more and more I look into the car, the more i get surprised!
rowdy85
#7 Posted : 17 May 2013 10:08:11
The after run oil is a good idea, but it fouls up the glow plug. And they usually need to be replace the next time you run your car.
#8 Posted : 17 May 2013 10:10:17
Untrue and is recommended by engine manufacturers. If you have concern of this, then simply remove the plug.
f1marshal
#9 Posted : 17 May 2013 15:13:25
all that oil and fuel over this build and if u race it the damage that could occur seems a shame to even fire it up Crying Confused Confused Confused
Paul
Current builds:
1/24 Spitfire
1/48 Apache Longbow
Titanic Lifeboat
rowdy85
#10 Posted : 17 May 2013 16:12:03
YES! lets just leave our RB7's as shelf queens BigGrin
