Hi there This is my first model ship! although I have built hundreds of aircraft some direct from plans my question is it ness to build a jig to keep the hull square? If anyone has done this could you advise me of how its done Thanks in advance clive
hi clive58, welcome to the m.s. forum, I'm not too sure how to answer this question, as you are such an experienced builder, I feel I am teaching my granny to suck eggs. did you use a jig to build planes?? I did, because they had to be straight and true on all planes, the same with boats,wood warps,and stresses are present that can easily warp keel/bulkheads, as it is your first boat, the same rules apply, and with many builds available it should be a cinch, looking forward to seeing your progress,  k. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
karl1113 wrote:hi clive58, welcome to the m.s. forum, I'm not too sure how to answer this question, as you are such an experienced builder, I feel I am teaching my granny to suck eggs. did you use a jig to build planes?? I did, because they had to be straight and true on all planes, the same with boats,wood warps,and stresses are present that can easily warp keel/bulkheads, as it is your first boat, the same rules apply, and with many builds available it should be a cinch, looking forward to seeing your progress,  k. Thanks Karl Yes always used jigs, I think ill wait till the first couple of bits arrive then get a building board and figure out how to jig it may just use small right angle metal brackets on the keel Cheers Clive
Hi Clive, I have recently been discussing jigs,as having had problems using metal brackets that are anything but square. If you want, take a look at the link below, as added to my own information others have added suggestions and useful links to other items that may help in your choice for a jig. http://forum.model-space...aspx?g=posts&t=6775
Good luck with your build. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Clive, in my opinion you should use a jig made from brackets you can buy from any DIY outlet for small money use a fibre board as this will not twist, but please please use one for the benefit of your model, here are some examples of what I call my DRY DOCK JIG:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
