Alternative applications of the 21XZ-M Speed Inboard Marine Engine. Options
VG30TT
#1 Posted : 17 May 2013 02:26:01
I've just seen this engine and got interested in what else it could be used for as its very powerful, revs very high and is water cooled.
#2 Posted : 17 May 2013 08:58:53
Its a marine engine, therefore marine use..
rowdy85
#3 Posted : 17 May 2013 16:23:46
its not like u couldn't use a computer water cooling system for it... or the 21XZ-R is the air cooled on-road version, it makes the same amount of power.
VG30TT
#4 Posted : 20 May 2013 00:19:56
A lot of automotive innovations have come from hybrid or cannibalised parts.
The idea about the computer water cooling system is what I had in mind, I just believe that with the higher cooling efficiency, running the engine harder for longer would be a desirable outcome.
rowdy85
#5 Posted : 20 May 2013 05:43:36
it's a cool idea, other people have tried a water cooled engine in r/c vehicles, which can be found with a little google-ing. I'd be keen to see you make it work. Do u have an idea for a water pump?
This page was generated in 0.178 seconds.
