Mast Parts Options
riff-raff
#1 Posted : 16 May 2013 17:25:12
Hi Guys
I have just received the last of the masts but I have not received any of the parts to connect the different parts of the masts together.
Do these come in a later issue or is this something else Diag have missed sending me?
The order the parts are supplied in leaves a lot to be desired !
Thanks Guys
Dave
Built:
petpole
#2 Posted : 16 May 2013 17:57:07
Hi dave, as you say you have the last of the mast parts was this a tube of doweling, because in earlier issues did you get some fret parts, that included some of the mast parts.
Hope this helps, if not pm me and I will try to help.
Peter.
BigGrin BigGrin BigGrin
riff-raff
#3 Posted : 16 May 2013 18:14:20
Hi Pete
I have all the "mast fighting tops" complete and the masts but I have no supports for any of these parts nor the parts required to fit the upper two parts of the masts together.
Dave
Built:
petpole
#4 Posted : 16 May 2013 19:25:25
The crosstrees come on the same fret as the radial lugs as memory serves me and the caps should be on a thicker fret that has the stern anchor davits on it.
Hope this helps.
If unsure please could you take a photo of all the wood fret parts you have, if not then when you log into the site for the build instructions at the beginning should be a parts list also on there are plans of what frets you should have.
Peter
BigGrin BigGrin
riff-raff
#5 Posted : 16 May 2013 20:27:00
I have just been and looked at the frets on the parts list and this is the one that I am missing:-
I have the caps but thought I had some missing but I have 7 in total. I assume:
2 for the main mast
2 for the fore mast
2 for the missen mast
1 for the bow spirit.
Dave
Built:
petpole
#6 Posted : 16 May 2013 22:32:49
Yes that's all the caps you need.
You need to ring customer services about the missing fret.
Sorry about that hope you get it sorted and hope I helped in any way.
If you require more help don't hesitate to ask.
Peter
riff-raff
#7 Posted : 17 May 2013 04:49:18
BigGrin BigGrin Thanks Pete.BigGrin BigGrin
This has been really bugging me, I wasn't sure if it was still to come or I should have it already.
A parts list is great, but a "with each delivery" would be good as wellGlare@c/.s
I'll get in touch when c/s opens later.
Cheers again
DaveBigGrin BigGrin
Built:
This page was generated in 0.172 seconds.
