To jig or not to jig? Options
clive58
#1 Posted : 16 May 2013 16:03:04
Rank: Newbie
Hi there
This is my first model ship! although I have built hundreds of aircraft some direct from plans my question is it ness to build a jig to keep the hull square? If anyone has done this could you advise me of how its done
Thanks in advance
clive BigGrin
#2 Posted : 16 May 2013 16:42:52
hi clive58, welcome to the m.s. forum, I'm not too sure how to answer this question, as you are such an experienced builder, I feel I am teaching my granny to suck eggs. did you use a jig to build planes?? I did, because they had to be straight and true on all planes, the same with boats,wood warps,and stresses are present that can easily warp keel/bulkheads, as it is your first boat, the same rules apply, and with many builds available it should be a cinch, looking forward to seeing your progress, BigGrin k.
clive58
#3 Posted : 16 May 2013 16:53:45
Rank: Newbie
Thanks Karl
Yes always used jigs, I think ill wait till the first couple of bits arrive then get a building board and figure out how to jig it may just use small right angle metal brackets on the keel
Cheers
Clive
#4 Posted : 17 May 2013 08:53:45
Hi Clive,BigGrin
I have recently been discussing jigs,as having had problems using metal brackets that are anything but square.
If you want, take a look at the link below, as added to my own information others have added suggestions and useful links to other items that may help in your choice for a jig.
http://forum.model-space...aspx?g=posts&t=6775
Good luck with your build.
#5 Posted : 17 May 2013 09:38:14
Hi Clive, in my opinion you should use a jig made from brackets you can buy from any DIY outlet for small money use a fibre board as this will not twist, but please please use one for the benefit of your model, here are some examples of what I call my DRY DOCK JIG:-
gilroy
#6 Posted : 25 June 2013 14:11:28
Rank: Newbie
This page was generated in 0.115 seconds.
