Tomick wrote:Hi Alan,
If it is an image taken from the Italian steps, then you can copy into this forum.. Thanks Mr T... appreciated... Mike this is what I am looking at... Hope it helps. Regards Alan Gandale attached the following image(s):
Gandale wrote:Nicely pointed out Mike, thanks for that... Would suggest you take a look at the Italian forum around issue 43, this may have a bearing on what you are trying to achieve in adding the additional port at the bow and what will need to be modified further in on the build.... Can't post an image as I don't have permission from the copyright holder... Hope it helps. Regards Alan Hi Alan, thank you for drawing my attention to Issue 43 I have taken this into account when I planned the gun ports, I will be adding the trim on the stem modified slightly  I am enjoying building this model so much because you can add so much of your own interpretation in to it.  kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Rank: Pro   Groups: Joined: 04/05/2012 Posts: 362 Points: 1,089
Still doing great work Mike And yes I`m fine, I just didn`t have much time for my Hobby My parents visited me and I became a wood-burning stove therefor I needed a connection to the chimney And while drilling, they cut through the powersuply
Hi Peter sorry you had so much bad luck  All the best Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
THE 13th GUNPORT After studying further models in the book by Sephton, I have resited the gun port 10mm further back, on my model. This has meant cutting away part of rib 2 on the side, which in my opinion has been well worth it have a look at the photos:- Kind regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 02/09/2012 Posts: 73 Points: 225 Location: York
As ever Mike, great to watch the modifications. Currently Building:
Eaglemoss HMB Endeavour De Agostini Sovereign of the Seas
Great work Mike, been thinking out this mod and think it is one I will do without.... Just not sure what problems it is likely to cause further down the line plus I do like the ornamentation at the bow..... Love what you are doing though..... Regards Alan
 Love the work Mike simply bril  Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Gus W wrote: As ever Mike, great to watch the modifications.
Hi Gus, thanks for looking in  thank you Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Gandale wrote:Great work Mike, been thinking out this mod and think it is one I will do without.... Just not sure what problems it is likely to cause further down the line plus I do like the ornamentation at the bow..... Love what you are doing though..... Regards Alan Hi Alan, thank you very much, for looking in and leaving your kind comments  I understand your reservations, you do whats comfortable for you in your build  All the best Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Martyn Ingram wrote: Love the work Mike simply bril  Rgd Martyn Hi Martyn, thank you for the nice comments  Kind records Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
THE 13th GUN PORT I have now finished the bow gun ports that I have added to my build, the coating of Dull black completes the job  Kind regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Nice job Mike  Next on my list,If I ever finish drilling holes that is Kind Regards Nigel
NMBROOK wrote:Nice job Mike  Next on my list,If I ever finish drilling holes that is Kind Regards Nigel Hi Nigel, thank you for your kind comment  I know what you mean there is always something to do  All the best Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
DRESSING THE TRANSOM Here is an update of my Transom modification work, please note this again is my interpretation of how I wish my build to progress. I have used walnut and box wood together on the transom, and the treenailing is done using cocktail sticks, in doing the treenailing I have tried not to be to even, infact some look at random because I want my ship to look well worn and not just launched, if that makes sense? I have used a piece of 2mm x 5mm walnut soaked it and bent it on the ship while it was still wet at the area where the Gallery back panel joins the Transom Planking. I hope the photos tell the story:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
DRESSING THE TRANSOM Well I have still got a bit to do before its finished, you will notice the burgundy caulking I have added, and I have pointed out the ledge with the box wood insert. Thanks for looking in the photos that follow will show you how it looks at the moment Kind regrds Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi Derek, thank you for your nice comments  I am afraid my secrets out!!!!  I am a member of a grannies knitting circle, keep it to yourself please  Cheers Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Now that I do not like Mike,,,,,, I love it..... stunning stuff... Regards Alan
Gandale wrote:Now that I do not like Mike,,,,,, I love it..... stunning stuff... Regards Alan Thanks Alan, I am pleased you like it  when it is finished with the final treenails put in and sanded plus cleaned with white spirit to bring out the detail before matt varnish, it will take on the look I am visualising  I hope!!!!! all the best Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
