27 Pages «<1617181920>»
The Military Quiz Options
#341 Posted : 09 May 2013 19:17:19
Ok here is the answer.
The Russians tried something called Slat armour, refered to as 'Bed spring Armour', as it looked similar to what it says!!LOL BigGrin They were trying to find and answer to the new German panzerfaust, and discovered that a steel frame with a steel mesh would disrupt the shaped charge of the warhead by either crushing it, preventing optimal detonation from occurring, or by damaging the fuzing mechanism, preventing detonation outright. Although slat armor is effective against incoming missiles, it does not offer complete protection – as many as 50% of impacts are unimpeded by the slat design. So they took a T34/85 and welded these frames with the mesh around the turret and parts of the hull.
On test day, all the high commanders arrived, and so confident were they that it worked, they asked one of the commanders to sit in the tank.
The test began. Unfortunately the soldier firing the panzerfaust was closer than had been tested, and consequently blew the turret off, killing the crew and the high commander!!
Despite the sudden demise of this commander and crew, the test was carried out again (on an unmanned tank this time!), and worked. The armour was used in battle and you can get models of the T-34/85 with this add on!!!BigGrin BigGrin
petpole
#342 Posted : 09 May 2013 19:53:31
So I wasn't far off then LOL LOL
Flapper Flapper Flapper
#343 Posted : 09 May 2013 19:55:01
50% There!! LOL LOL LOL BigGrin BigGrin
#344 Posted : 09 May 2013 19:58:27
Ok another question!! Easy one!!LOL BigGrin
What were the main ingredients of Zimmerit?
petpole
#345 Posted : 09 May 2013 20:13:17
40 % Barium sulfate - BaSO4
25 % polyvinyl acetate – PVA (similar to wood glue)
15 % pigment (ochre)
10 % Zinc sulfide – ZnS
10 % sawdust
Flapper Flapper Flapper LOL LOL
Peter
#346 Posted : 09 May 2013 20:16:30
10 % sawdust
Peter
You been making it?!?!?!LOL LOL LOL LOL LOL LOL
Correct sir, over to you Peter!!BigGrin BigGrin BigGrin
petpole
#347 Posted : 09 May 2013 20:29:44
The Grille was a weapon built in 1943.
1: Can you name the place where the first batch was built?
2: And what was its official designation?
It's an easy one but I'm not to good at these quizzes LOL
Peter
#348 Posted : 09 May 2013 20:32:19
The Grille, German: "cricket" was a series of self propelled artillery vehicles]. The Grille series was based on the Czech Panzer 38(t) tank and used a 15 cm sIG 33 infantry gun!!BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin
petpole
#349 Posted : 09 May 2013 20:39:58
Your close to both answers but its not the nickname I'm looking for LOL and what was the city.
I'll give that you got it right.
Flapper
#350 Posted : 09 May 2013 20:58:54
produced in the BMM (erstwhile ČKD Praga) factory in Prague from February to April 1943. The official designation was 15 cm Schweres Infanteriegeschütz 33 (Sf) auf Panzerkampfwagen 38(t) Ausf. H (Sd.Kfz. 138/1!!!! Flapper Flapper Flapper Flapper LOL LOL LOL BigGrin BigGrin BigGrin
#351 Posted : 09 May 2013 22:11:37
That's some answer Nem LOL
petpole
#352 Posted : 09 May 2013 23:16:18
Well done nemesis LOL LOL
It's over to you now.
Flapper Flapper
#353 Posted : 09 May 2013 23:38:18
Well I was always told if your gonna do it, then do it properly!!!!LOL LOL LOL LOL LOL LOL LOL
#354 Posted : 10 May 2013 00:03:12
Which tank was driven by 2 x 9 meter diameter wheels?Blink BigGrin
petpole
#355 Posted : 10 May 2013 00:50:20
The Russian 1915 tricycle
Flapper Flapper LOL LOL LOL LOL
SennaMentalMe
#356 Posted : 20 May 2013 17:07:06
We are waiting on your response Daran!? We need to keep the quizzes moving or they die!!Glare BigGrin
Kev BigGrin
#357 Posted : 20 May 2013 18:51:28
I will give you half for that but what was it called?Flapper Flapper LOL LOL BigGrin BigGrin
budgie
#358 Posted : 20 May 2013 21:13:19
Blushing A big oneBlushing
petpole
#359 Posted : 20 May 2013 21:54:48
The lebodenko tank was it?
Peter
#360 Posted : 20 May 2013 22:10:47
There was one of three answers you could have give, and that was one of them!!!LOL LOL
The Tsar Tank, and also known as the Netopyr' would also have done!!LOL LOL
Your question sir!!!BigGrin BigGrin
Guest (8)
