25 Pages «<89101112>»
Claret's SOTS Build Diary Options
Hans
#181 Posted : 29 April 2013 10:00:11
Great looking job there Claret, steady as she goes.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
#182 Posted : 29 April 2013 18:44:41
BigGrin Nice work Claret BigGrin Happy Building Rgd Martyn
claret
#183 Posted : 07 May 2013 08:49:26
Hi Dominic,
Thanks for the kind comments, I ahve been watching your plastic builds with interest. Awesome!!
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
claret
#184 Posted : 07 May 2013 08:50:33
Hi Hans & Martyn,
Thanks for looking in and posting those words of encouragement.
Much appreciated.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#185 Posted : 09 May 2013 09:19:57
Hi all,
Fixed the plank under the gallery.
Soaked it first in hot water, bent it into shape and held it in situ with pins until dry.
once dry, I pulled the pins out, glued it back into its place and re-pinned. Once the glue had cured, the pins were removed.
The plank was then sanded into the correct profile.
That's all for now. More to follow later.
Claret.
Also working on:
SOTS.
finished:
007 Iconic DB5.
#186 Posted : 09 May 2013 10:06:47
BigGrin Going well Claret . Keep the pic's coming ThumpUp Rgd Martyn
claret
#187 Posted : 09 May 2013 12:43:57
Thanks Martyn, will do.BigGrin
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#188 Posted : 09 May 2013 13:51:01
Hi,
Progressing with the 'upward' planking, pics below;
more to follow....
claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#189 Posted : 09 May 2013 14:08:13
Hi again,
When i had finished the planking, i masked off all the non planked areas and sprayed the planking with grey primer, fortunately the bank holiday weekend here in the north west was nice enough to do this outside (no way would I have had permission to do this inside!).
24 hours later, I removed the masking tape and set about sanding the hull, using p80 paper first. several hours later (not non-stop) the grey primer had been removed, leaving a few recesses that needed filling. these were filled and duly sanded. I finished off with fine sand paper p150.
A couple of areas where the bambo may be a little thinner that I wanted, but on the whole the result was okay.
pics below:
Thanks for looking in.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
court orchard
#190 Posted : 09 May 2013 14:22:58
Looks GoodThumpUp
NMBROOK
#191 Posted : 09 May 2013 14:50:48
That's a lovely bit of planking an ideal base for the next layer.
Kind Regards Nigel
Admiral Anti Spiral
#192 Posted : 09 May 2013 15:01:31
Lovely work claret, looks very smooth!
Processing - Progressing
Previous builds: HMS Victory
KobusBeukes
#193 Posted : 09 May 2013 17:39:30
Hi Claret
She looks good! Just started with my build, upto issue 5, and looking forward to all the updates!
Enjoy
Kobus
Current Build
HMS Sovereign of the Seas - First Build
#194 Posted : 09 May 2013 22:13:28
Hi Claret, very well done indeed. Think you have done a great job, keep that great work going.... BigGrin BigGrin
claret
#195 Posted : 10 May 2013 14:06:28
Hi Andy, Nigel, AAS, Kobus Beukes & Alan,
Thanks for all your kind words.
The hull is surprising smooth after all the sanding.
I read in a couple of diaires of sore arms etc. My thoughts were ' from a little sanding?'Confused How nieveLOL I too had the symptoms of sanders elbow for a couple of days.
Hopefully this weekend, it will be marking the hull up for cutting and adding the canon ports, still looks daunting.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#196 Posted : 10 May 2013 18:40:38
BigGrin The hull look's bril ThumpUp Good luck with the gun port'sCool Rgd Martyn
#197 Posted : 10 May 2013 19:18:19
Hi Claret good stuffBigGrin kind regards Mike
#198 Posted : 10 May 2013 19:32:37
Hi Claret,
All credit to you Cool , that looks good. I`ve just completed lower planking, so got more planking and sanders elbow,wrist and fingers to look forward to. LOL LOL LOL
claret
#199 Posted : 21 May 2013 11:23:56
Hi Mike & Derek,
Thanks for the comments and looking in.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#200 Posted : 21 May 2013 11:35:31
Hi,
Have started to cut the gun ports out, first one done after measuring out all the ports on the one side. Measuring and rechecking before drilling a centre hole and one each corner within the marked area about a 1mm from the edge. I then cut the waste area out with a small saw that came with my scalpel set. Then using emery board, sand, measure with a vernier, sand and measure until the right size acheived.
A spirit level was used to ensure the ship was level and the gun ports were also.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
Guest (14)
This page was generated in 0.278 seconds.
