2 Pages <12
caulking the decks of hms victory. Options
steve p
#21 Posted : 31 May 2010 11:31:06
Rank: Amateur level 2
The method I used on the bounty was to run a very sharp pencil (this keeps the lines from being to wide) between each plank and across the joints, for the nails just place pencil near to joints and twist with slight pressure. To get the feel practice on a scrap piece beforhand lightly sand down , this will remove any harshness
#22 Posted : 31 May 2010 23:48:50
most of the suggestions i have read seam to offer a very precise line. i wonder how neat this was in reality. i seem to recall the tar between the deck planks on the original victory deck was quite well uneven. I had planned on a fine fiber tip pen after sanding but i am not sure if the ink will spread?
Mike Turpin
#23 Posted : 01 June 2010 00:20:33
I used a fine pointed black ink pen on HMAV Bounty and what little spreading there was just created the uneven line that you noticed. It would be uneven on the real ship because the tar spreads a little and on the upper deck tends to melt and reset in hot weather.
Mike T
#24 Posted : 01 June 2010 00:43:34
thanks matey i think i will try that and as always your historical knowledge is most helpful
snowtiger
#25 Posted : 01 June 2010 01:17:07
Jase use an art pen....any size...then press the edges down the edges with a small nail ....that will give you the desired....effect you are looking for..BigGrin
Tarbrush
#26 Posted : 01 June 2010 18:21:31
Hi shipmates,
On HMS Beagle (Mamoli kit) they suggest running a soft pencil down each edge of the plank before laying it. Although the instructions leave a bit to be desired in other areas,this seems to work quite well as the result is not to bold and looks realistic.BigGrin It is certainly better than trying to follow the join afterward.Blushing I suppose if you wanted a darker result a black felt tip would be good.LOL
amipal
#27 Posted : 06 June 2010 13:46:02
All of these suggestions are pure gold - hadn't even considered the caulking. Thanks chaps! Cool
#28 Posted : 08 June 2010 21:35:08
Great topic Karl,
I used a pencil on a model of the Bounty to good effect, but I am open to any method that is within scale and authentic
Cheers
PDyner
#29 Posted : 09 June 2010 17:10:09
Hi All
My name is Prem. I mainly make plastic or carton models. This will be my second attempt to make fully wood model.
To put my word in this disscution I've usually used a marker pen for this job at my others ships. In my opinion it has to be good quality marker to write on "everything", otherwise during sanding it will be spread all over the deck making it much darker with grey dust. I've used Pelikan marker and it was OK. And I think it easier to use wider than thiner.
Prem Dyner
Cornwallray
#30 Posted : 19 June 2010 00:25:21
I will be trying Bonded Nylon Thread I picked this idea up from another forum and it did look very nice.
Built
Billings Le Bayard
Mamoli Golden Hind
Corel Shenandoah
In Progress
AL King of the Mississippi
Mantua HMY Britannia 1893/HMS Victory 1/98 Stopped
Yet to start
AL Zuiderzee Botter (Pre laser)Fun fun fun
Constructo HMS Victory
Caldercraft HMS Victory
Deag HMS Victory
SteveJ
#31 Posted : 19 August 2017 16:34:40
I have used a permament marker in the past. However I use 'Easy Polish' which is a quick dry French Polish which gives a superb finish, and this caused the marker to run. I now use a 2B pencil to mark the edges. This gives a nice fine line after sanding, without being tooo wide and looking out of scale.
2 Pages <12
