Joined: 02/09/2012 Posts: 515 Points: 1,515 Location: Burnley
hi Derek, Planking looking good. I have pre-drilled my planks, tapped the pins in before gluing and offering unto the hull. The pins have been tapped in once held in position with a small hammer, although I have been told of a few times for the constant tapping in the evening. I will upset the neighbours Don't seem to mind their dog barking at 7am when they go out.... anyway of my soapbox Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Waiting in the wings: Polarlights Spindrift from Land of the Giants.
finished: 007 Iconic DB5.
Joined: 20/10/2010 Posts: 511 Points: 1,459 Location: Loughborough
Hope you backs ok delboy I know how you feel been off work for a week myself I suffer with sciatica and arthritis in the neck so I have to do things in little doses that's why my builds take so long, but hay ho I keep on building hope you do to great build so far keep it going. Builds in progress: HMS Victory.HMS Surprise. Completed builds: Revell London Bus 1/24. Builds to do:Sovereign of the seas, Hms Albion.
Cheers Petpole, Doc`s increased the pain killers and signed me off for another week, hey-ho,but the build`s ok, just dry fitting stern hull planks at the moment to get a good fit to the bottom of the transom. Thanks for looking in and hope your build is going well. regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
claret wrote:hi Derek, Planking looking good. I have pre-drilled my planks, tapped the pins in before gluing and offering unto the hull. The pins have been tapped in once held in position with a small hammer, although I have been told of a few times for the constant tapping in the evening. I will upset the neighbours Don't seem to mind their dog barking at 7am when they go out.... anyway of my soapbox Regards Claret Cheers Claret, Thanks for looking in, pre-drilling and pinning is working well for me,as for the tapping you need a second hammer, small for your pins and a bigger one for the neighbors, don`t go with cruelty to animals, hence hit the owners.  . Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Derek, hope the back is on the mend and you can still continue with your build..... without the spasms and mishaps....
Hi All, Just a short update on the ever lovable planking. My next delivery 26-29 should see an end to the first session of the planks  . I will just post the pics as I don`t think any script is needed at this stage. Just one comment here: some of the plank ends not good but should be easily cured later. Well that`s it for now, waiting for next delivery and going on me hols soon so will update at a later stage. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Derek, coming along nicely. You are almost there and you always have your other builds to give you a break from the planking... I must be ill or something as planking is part of the build I have really enjoyed..  .. Keep up the good work..... Regards Alan
Gandale wrote:Derek, coming along nicely. You are almost there and you always have your other builds to give you a break from the planking... I must be ill or something as planking is part of the build I have really enjoyed..  .. Keep up the good work..... Regards Alan Hi Alan, Everyone has their funny habits, yours must be planking. Thanks for looking in. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi All, Well holiday over and back at work  . So here is a bit of an update as I have now reached the end of issue 25. I have taken a string of pics around my build,as it stands at the moment:- So there we go. Any comments and/or advice would be gratefully received. Next job is to close the gap at long last Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Looking good delboy  Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Hi Derek, You are getting there  Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Martyn Ingram wrote: Looking good delboy  Rgd Martyn Cheers Martyn Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
MWG wrote:Hi Derek, You are getting there  Kind regards Mike Cheers Mike, Thanks for looking in, only got the Victory and Elbe(See Ewer)planking to look forward too and second layer of the SOTS. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Derek, nice to see you back on your builds, hope you had a wonderful holiday.... You practicing to be a mathemetician using the side of your hull as a scribbling pad..  .. Progressing nicely so keep up the good work..... Regards Alan
Gandale wrote:Hi Derek, nice to see you back on your builds, hope you had a wonderful holiday.... You practicing to be a mathemetician using the side of your hull as a scribbling pad..  .. Progressing nicely so keep up the good work..... Regards Alan Hi Alan, Thanks for looking in, Yep holiday was great  ,as for the mathematics  , I cut several planks at the same time and added the notation to get them in the right place, with the right orientation. Forgot they were there DOH  . Will vanish with the sanding when that job arrives. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi All, This is my latest update and takes me to the end of planking the lower hull with bamboo. I don`t think there are any major prob`s, but any comments and or advise will be gratefully accepted. So now have to start upper planking, get my Victory build into the keel jig and get some planks for the "ELBE". What do I do after tomorrow, Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Nice work Derek  Of to specsaver's you go  Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
