36 Pages «<2829303132>»
#581 Posted : 04 May 2013 16:46:10
canoe21 wrote:
Hi Mike; Thanks very much for the picture of the Cathead Crowns it sure will be a great help when I get around to painting mine.
Regards Lawrence
You are welcome LawrenceBigGrin Kind regards Mike
canoe21
#582 Posted : 05 May 2013 00:40:30
Hi Mike; is it possible for you to send me the painting instructions. They are missing in your PDF, I have the Transom & Quarter Gallery Skins. Transom & Quarter Gallery Decoration, The Name Plate and also The Binnacle. No hury I just wanted to took them over.
Regards Lawrence
#583 Posted : 05 May 2013 09:57:12
Regards Lawrence
Hi Lawrence, If you look back through my build Diary you will find a painting Tutorial for the Gallery EnhancementBigGrin Kind regards Mike
canoe21
#584 Posted : 05 May 2013 13:45:52
Hi Mike; Sorry about that, what I realy wanted to know is the width of the inside vertical window frames as they seam narlier than the out side frames.
Regards Lawrence
#585 Posted : 05 May 2013 15:30:19
GALLERY ENHANCEMENT PAINTING THE BRASS ETCH
I have already sprayed the etch with primer (as in my previous posts)now I brush on a thin coat of Admiralty yellow ochre, this will be the first of approx 3 thin coats (do not have too much paint on your brush)
More photos to come.
Kind regards Mike
#586 Posted : 05 May 2013 17:56:21
Hello Mike,
Nice work,watching with interest .
Trev.
#587 Posted : 05 May 2013 21:18:57
tf64 wrote:
Hello Mike,
Trev.
Hi Trev, thank you for the nice commentBigGrin Kind regards Mike
#588 Posted : 06 May 2013 07:54:22
Regards Lawrence
Hi Lawrence could you provide a photo of the area you are wanting an answer on?BigGrin Thank you Mike
Jesus-Belzheim
#589 Posted : 06 May 2013 19:19:15
Nice paintingwork Mike ThumpUp
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
#590 Posted : 06 May 2013 21:26:02
Cheers Peter please look for the next instalement Kind regards Mike
#591 Posted : 07 May 2013 16:51:22
Hi Mike.
Looking good. look forward to seeing your progress.
Ian. BigGrin
#592 Posted : 08 May 2013 10:32:36
ian smith wrote:
Hi Mike.
Ian. BigGrin
Hi Ian thank you for your nice commentsBigGrin Much appreciated Kind regards Mike
#593 Posted : 08 May 2013 22:33:33
Beautiful work Mike and to know this enhancement will be fitted to my vic, hopefully to your standards makes it all the more desirable.....
#594 Posted : 09 May 2013 09:11:10
Hi Alan, thank you, it is beautiful to work withBigGrin you will have no problem with itCool your comments are appreciated
Kind regards Mike
#595 Posted : 02 July 2013 01:52:26
Hi Alan, I Have sent you the PDF instructions for the Gallery and Binnacle
Kind regards Mike
sparks
#596 Posted : 02 July 2013 20:30:12
Nice job on the brass etch painting Mike ThumpUp
#597 Posted : 03 July 2013 01:42:35
Hi Alan thank you for your nice commentBigGrin Kind regards Mike
#598 Posted : 04 October 2013 21:32:40
PAINTING THE GALLERY BRASS ETCH
Hi Everyone, at the last post of my build diary I applied the first coat of yellow ochre to the already primed surfaces. Now at this stage I am making sure the brass etch fits the contours of the sides and rear gallery, by gently bending the etch to fit (for a second time), and the good news is it has note cracked the paintBigGrin
#599 Posted : 04 October 2013 21:39:30
Now I am applying the 2nd coat of yellow ochre paint to the brass etch, making sure the coat is very thin,(this will be the second of three coats)
The photos explain the processBigGrin Questions and comments welcome Kind regards Mike
sparks
#600 Posted : 04 October 2013 22:03:39
Nicely done Mike.
Guest (5)
