http://www.hk-models.de/index.htm
Looks like they also have a 1/32 Lancaster in the pipeline..
I see your at it again - encouraging me to spend more of my hard ernd lancaster sounds good though “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
pre-ordered the Lanc and B17
 Rank: Pro Groups: Registered
Joined: 05/12/2012 Posts: 258 Points: 754 Location: manchester
A review of the B17G..http://www.scaleplastica...fortress-from-hk-models
I found this quite interesting..."The last addition that has been included is a support stand... I can see you all asking why a support stand is require if the model builds up structurally??? Well, HK Models idea for the stand is quite neat... I know most people will have an issue on displaying the kit once complete, so this is where the stand comes into play! It's been designed to be screwed on the a wall surface of a room or a mounting board and clips into the bomb bay area of the kit, allowing the B-17 to safely mounted on the wall." A great idea for dispalying such a large model!
Great post Tom!!
There is another great preview here:
http://www.themodellingn...le-modelling-folks.html
If you scroll down the page to about 75% down, it shows the stand that you mention?
Does look like a very cool model I must say, with some great internal detail!!
Kev
Some great reference links and good to see so many positives with the kit but I must ask you all to stop it as mine has not arrived yet and it's not fair to tease!!
Certainly is a big'un!!!
Mind you, I have the Revell 1:48 Rockwell B-1B Lancer in my stash and that is over three feet long!!
Kev
I believe it is the biggest plastic aircraft kit to this day, though the new models from HK above may challenge it a bit!!
I've also got ALL of the Eduard etch sets for it - internal, external and the exhaust cans sets, plus the metal undercarriage upgrades from 'Scale Aircraft Conversions' and some aftermarket decals and RBF tags.
May build it one day, though heaven knows where I would put it when finished!!
Kev
