Hi Lawrance, Here are the measurements that I used for my table,as I said there not to scale I just made them up as I went along,(pictures H/W). Regards Trev.  Table 60mm Table Width 16mm  2mm Thick.   All the best Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Joined: 18/11/2012 Posts: 19 Points: 57 Location: Sutton, Ont., Canada
Hi Trev, thank you very much for the pictures and the sizes. I am sure they will look fantastic in Mikes Gallery. Lawrence
Hi, Been away to long from this Forum flying model helis so I thought you my like to see how I have got on with the Hull Coppering, just the odd bit to finish off then push on with the rest of the build. Regards to all. Trev.     Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Cracking job on the hull coppering, very well done indeed.... Regards Alan
 Hi Trev Welcome back and you have done a cracking job on the copper plates Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Great job, how do you keep them so shiny?
Thank you Gandale,Andy,and John for taking the time to look at my build. well John said how do I keep them so shiny,I will post a few more pictures and you can see what I did guess you have to have a bit off nerve after 6 months tiling.        And the rest is in the wrist. Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Some nice pics and the tiling looks great. are you going to lacer them or levee them to tarnish and age naturally? “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Hi the copper looks fantastic, well done and nice to see you back. Steve
Hi Jase, Thanks for looking in,we'll it took me 6 months to do and the only way I found to remove and settle the tiles was to rub down with wet & dry,and then I found it all looked much better then polished by hand. So with all that rigging and bits.I will let it age naturally. Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Steve, Thanks for looking and for your comments,look forward to seeing your build. Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Thats some mighty fine tiling Trev!! Spencer
Thank you Spencer Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Looking great Trev
How about some photos of your helis, sounds like you've been having fun
tf64 wrote:Hi Jase, Thanks for looking in,we'll it took me 6 months to do and the only way I found to remove and settle the tiles was to rub down with wet & dry,and then I found it all looked much better then polished by hand. So with all that rigging and bits.I will let it age naturally. Trev. my thoughts as well. “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Hi Trev. Fantastic job on your tilling. Look forward to seeing more. What helecopters do you fly. Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
 Hi Trev Your method of polishing the tiles has also added an unforsean bonus as you have filled all the gaps with a natural looking dirt and thus aged the tiles ,nicely done Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Ian, Thank you for looking in ,as you know coppering can put your mind in a state of disorder,but well worth it how are you doing with yours. Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hello Andy, Thanks for your comments,it was more desperation to think of away to remove the glue stains,I used CA thin very good but a bit messy. Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Mr T, Thank you for your comments,yes I have had fun this year with my helis also I have had fun repairing them,at present I have , 3 Syam SO 319s 1 flying. Other two are spares. 1 Syam SO 339 3D yellow. 1 Syam SO 22 SO 310s are a bit limited but good for basic training. SO339 3D this is more advance model than above great to fly. SO 22 this a small Army Chinook good to fly but small. This year I upgraded to KDS Innova 450 QS this is a beast with its on rule book should you let it,this model has no morels it will trim anything in it way, it will fly upside down and mow the lawn if you let it.I have still to master it !! Regards Trev. www.kdsmodel.comWork in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Guest (6)
