Hi Claret, a really nice job  Good stuff Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Rank: Vice-Master        Groups: Registered
Joined: 17/11/2012 Posts: 863 Points: 2,608 Location: Gohfeld (Germany)
Hi Claret! Well done, a very nice work! Keep on this way! Regards, Bernd
Joined: 02/09/2012 Posts: 515 Points: 1,515 Location: Burnley
Hi Alan, AAS. & Derek, Thanks for your encouraging comments. Looking a the Italian build, it looks like we sand down the bamboo planks to 2mm from the back of the false keel. Mi think I will be okay with what I have done. Thanks again for pointing me in the right direction. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Waiting in the wings: Polarlights Spindrift from Land of the Giants.
finished: 007 Iconic DB5.
Hi, I have been busy doing the model, but not had a chance to update the diary. Progressed on the launch, pic below.  Also been progessing with the planking as shown.   More to follow. Regards claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Looking good Claret, well done.... Regards Alan
Hi Alan,, Thanks for looking in and commenting Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Good clean job you have there, Claret, well done. She sure has some beautiful lines. Keep it up. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Hi Hans, Thanks for the kind comments. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi, I have a back log of photo's showing the bottom half of the hull being finished. Planking is a little ropey in places, but I am hoping sand paper and elbow grease will sort it out. Here is my progress..    Claret. Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi, And continuing on from the last post, I have ensured I have used copious amounts of glue along all the plank edges and on the rib forms.    A view of the bow..  Almost complete!  Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi, I glued the back parts, which fitted very well, added the dummy gun supports, using pins from behind, plenty of glue and a few off cuts to add more support.    Then started to plank upwards.      Thats all for now. Thanks for looking in. Claret. Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
WTG Claret, That`s looking good M8. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Very nice work Claret, looks as if she will sand down very nicely.... Good job... Regards Alan
H Alan, Thanks for the kind comments. Slow progress at present, fitting last rows of planks with no ribs to clamp or pin to. Gluing one row, clamping them and allowing the glue to cure for 24 hours. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi Claret! A really nice and clean work, well done! Do you only glue the planks on the ribs or do you also glue them to each other? I always also glue them at the thin side of the wooden strip to each other because with this I get better results and don´t have to sand very much. Also preparing the gunports is easier. Regards, Bernd
 Nice Build Claret  Rgd martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Hi Claret, a nice clean build  Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Thanks Mike. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi Bernd, Thanks for your kind comment. I glue the planks to the ribs and to each other along the length, using copious amounts of glue. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi Martyn, Thanks for looking in and posting the encouraging comment. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Guest (14)
