Sanding @ Filling Options
#1 Posted : 26 April 2013 09:07:04
BigGrin I am sanding and filling the hull . Is it ok to put on a thin wash of PVA to seal it for the 2nd layer of plank's Blushing Thank's MartynBigGrin
#2 Posted : 26 April 2013 09:26:46
Hi Martyn, you may be better with a thin skin of wood filler....
#3 Posted : 26 April 2013 10:03:20
BigGrin Hi Martyn
A good idea is to spray the hull with a coat of grey undercoat [ or similar] 1st then when you start sanding this will show up quickly any high/low spots you may have on the hull. The high spots are just sanded back whilst any low spots can be filled . As for the PVA sealer I don't think it will make that much difference but its up to you. Hope this helps
#4 Posted : 26 April 2013 11:08:31
arpurchase wrote:
BigGrin Hi Martyn
Hi Martyn, if you use the spray methode as Andy suggests please make sure you mask off the deck areas as spray paint can ge through small gaps.
What I do with period ships is sand smooth fill any inperfections with ronseal wood filler (I do not use PVA to cover as it does not sand easily) when I am happy with the smoothness of the hull I then seal the hull with sanding sealer,then I find the second layer of planks fixes spot on. Aliphatic adhesive I find is much better suited to period ship builds as it sands easily.
The above is what I do other modellers will also have a system that works for them, I hope that helps
Kind regards
Mike
Admiral Anti Spiral
#5 Posted : 26 April 2013 13:09:32
what i've done is brush some watered down pva glue on the inside of the hull just for the sake of reinforcement, also added some thin strips of wood in certain places, but for the outside i dont think theres much need, it might effect the way you glue the 2nd layer on the hull, but i've also done as andy suggests, its a good idea :)
Processing - Progressing
Previous builds: HMS Victory
#6 Posted : 26 April 2013 18:34:49
BigGrin Thank's all for the info .I think I will go with Mike and use sanding sealer. Happy BuildingBigGrin
