 I am sanding and filling the hull . Is it ok to put on a thin wash of PVA to seal it for the 2nd layer of plank's  Thank's Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Martyn Ingram wrote: I am sanding and filling the hull . Is it ok to put on a thin wash of PVA to seal it for the 2nd layer of plank's  Thank's Martyn Hi Martyn, you may be better with a thin skin of wood filler.... Regards Alan
 Hi Martyn A good idea is to spray the hull with a coat of grey undercoat [ or similar] 1st then when you start sanding this will show up quickly any high/low spots you may have on the hull. The high spots are just sanded back whilst any low spots can be filled . As for the PVA sealer I don't think it will make that much difference but its up to you. Hope this helps regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote: Hi Martyn A good idea is to spray the hull with a coat of grey undercoat [ or similar] 1st then when you start sanding this will show up quickly any high/low spots you may have on the hull. The high spots are just sanded back whilst any low spots can be filled . As for the PVA sealer I don't think it will make that much difference but its up to you. Hope this helps regards Andy Hi Martyn, if you use the spray methode as Andy suggests please make sure you mask off the deck areas as spray paint can ge through small gaps. What I do with period ships is sand smooth fill any inperfections with ronseal wood filler (I do not use PVA to cover as it does not sand easily) when I am happy with the smoothness of the hull I then seal the hull with sanding sealer,then I find the second layer of planks fixes spot on. Aliphatic adhesive I find is much better suited to period ship builds as it sands easily. The above is what I do other modellers will also have a system that works for them, I hope that helps Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 24/09/2012 Posts: 491 Points: 1,452 Location: London
what i've done is brush some watered down pva glue on the inside of the hull just for the sake of reinforcement, also added some thin strips of wood in certain places, but for the outside i dont think theres much need, it might effect the way you glue the 2nd layer on the hull, but i've also done as andy suggests, its a good idea :) Processing - Progressing
Previous builds: HMS Victory Current build: HMS Sovereign of the seas
 Thank's all for the info .I think I will go with Mike and use sanding sealer. Happy Building Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
