sandnesspeats wrote:hi karl, I tried to delete and re post but it would not show them. this is the first time this has happened, don`t know how this has happened as I have not changed the settings on the camera. if you can help how to change the size of them so it will show that would be great. thanks rob
click on your pics first,select the one you want to put up,then click on edit pic, go to resize, change to 800x600 then save, click on post a reply, put a tick in the attach file box, click post, and another box appears, Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
click on your pics first,select the one you want to put up,then click on edit pic, go to resize, change to 800x600 then save, click on post a reply, put a tick in the attach file box, click post, and another box appears,hit the choose file button,and select the resized pic and hit the upload button,you can then select another resized pic. when finished hit the back button to load pics on reply page. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Joined: 20/12/2011 Posts: 236 Points: 686 Location: shetland
here goes with the photos Thanks Karl for your info. sandnesspeats attached the following image(s):
karl1113 wrote:ok rob,the hole is def. not in the middle is it. so a bit of back tracking required, replace some deck flooring and start again,cut dead centre hole,before gluing,you might have to go lower down,to widen lower deck hole to get the mast straight. leave it any longer and will be too late to fix. good luck,and take the repair as a phase in the building. k. Hi karl, The thing is that everything is glued,never thought to check before putting the cabins in  . It was only when I measured the center line that I found out about it being off,I was horrified Thanks again
Ouch, that hurts!! It should be no big problem to adjust the poop and the quarter deck. But the lower decks won`t be easy - a long file is all that i can think of. I wish you the best of luck. Greetings, Walter
Hi dadokta, thanks! you can say that again it was a sore one. I do have long round file hope this will do the job slowly but surely. I hope it is hidden after I have finished adjusting it. cheers rob
Rob, so sorry to see this problem with your build,  really hope it works out for you... Take your time on this repair, double check all your measurements before starting to cut... Once you have the mast in the correct position replanking part of the deck should cover most of the repair....  . Fingers crossed for you as your build is really coming on a treat..... Regards Alan
Thanks for that Alan, I suppose this is the cause of first time building of this type, I posted this earlier and thought I had it but obviously never checked it enough,just have to see what I can do with it and check the other two masts at the same time. I will post after the big  OPERATION  . Thanks again for the confident remarks. rob
Rob, would suggest you take some pics as you progress with the repair, keeping these in reserve in case you need to publish to get some more advice as to the best way forward..... Will be keeping everything crossed for you for a successful repair..... Regards Alan
Hi Rob, feel your pain. as the others have said take your time re-measure and repair, good luck and wishing patience ad success. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Hans wrote:Hi Rob, feel your pain. as the others have said take your time re-measure and repair, good luck and wishing patience ad success. Thanks Hans, "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" I like your quote makes us think we are all human Just have to see what happens, I will post pics just in case any new builder comes on, something to look out for. cheers again rob
Gandale wrote:Rob, would suggest you take some pics as you progress with the repair, keeping these in reserve in case you need to publish to get some more advice as to the best way forward..... Will be keeping everything crossed for you for a successful repair..... Regards Alan Thanks again Alan, will post pics as I said earlier to help newbies to watch out for in their build. cheers rob
I think I am there, the center mast was off too, don`t know if you can see them properly so here goes. I put some balsa wood to hold it place for the time being. sandnesspeats attached the following image(s):
that looks soooo much better,well done that man, give yourself a good pat on the back.  k. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Now that looks much better Rob, well done.... when finished doesn't look as if it will be noticed....
karl1113 wrote:that looks soooo much better,well done that man, give yourself a good pat on the back.  k. Thanks Karl a bit fiddly but got there. great input rob
Gandale wrote:Now that looks much better Rob, well done.... when finished doesn't look as if it will be noticed.... Thanks Gandale,just have to tidy it up now. thanks for the input  rob
Noone will ever notice, once you are finished! Greetings, Walter
Hi DaDokta, I was afraid it might have been seen, but gladly you verified it for me. thanks again rob
Hi all, I have a gap on the sides on the top deck and nothing to lay a plank on to, I have put a bit of wood level with the planking on the side. Could anybody tell me if this will interfere with anything later in the build. Thanks in advance rob sandnesspeats attached the following image(s):
Guest (10)
