DRY BRUSHING Options
daffy09
#1 Posted : 19 April 2013 13:05:53
Hi Shipmates
In following some our our members build diaries, I've noticed that some of them refer to a term called "DRY BRUSHING" when painting their models.
Could somebody enlighten me as to what this technique is and how it is done?
Many thanks and happy building
David
petpole
#2 Posted : 19 April 2013 13:42:08
This video might help you to explain dry brushing.
http://youtu.be/cT6Oe3GV7Uk
BigGrin BigGrin BigGrin
#3 Posted : 19 April 2013 18:59:02
Hi Daffy
I've been using the dry brush technique quite a bit on my DelPrado Victory, I've got a bit more to do on her hull soon so I'll be putting in a little 'how I did it' tutorial-type bit in the next week or two which will explain some of the techniques I used. Blink
It's a very simple procedure but very effective if done spareingly!
Happy building BigGrin
(Thanks for that link Petpole, I'll have a good look on there!)
Robin
#4 Posted : 19 April 2013 20:49:44
Hi Daffy,
Dry brushing became fasonable in the late eighties when Verlinden developed his wash and dry prush weathering technique.
very simply its a method of highlighting. you loead a brushe and then remove the paint from the brush with a piece of tissue until there is almost no paint left. then gently drag the brush over some textured area. the high points will catch the paint. so on a figure for example you could paint the trousers a colour then do a wash a couple of shades darker then dry brush a couple of shades lighter to add texture. I have recently used it on my bismark to paint the grills and not clog the holes with paint.
Hope that helps you can probably find some tutorials on the internet I did do a wethering post some time ago but can not remember where i put it Blink
daffy09
#5 Posted : 19 April 2013 21:26:42
Thanks guys that was very helpful. I'll be trying out some of these techniques when I get on to the cross-section which I will be painting.
Thanks again
David
