56 Pages «<4950515253>»
#1001 Posted : 15 April 2013 22:36:13
ISSUE 67 TO 69
Hi Everyone, what follows are the photos of the continuation and finish of the above issues:-
#1002 Posted : 15 April 2013 22:49:03
ISSUE 70
Continuing the build of the centre deck:-
#1003 Posted : 15 April 2013 22:51:21
Looking good Mike ThumpUp
#1004 Posted : 15 April 2013 22:52:23
ISSUE 71
More build of the centre deck:-
#1005 Posted : 15 April 2013 22:56:08
ISSUE 71
Thata all for nowBigGrin Kind regards MikeBigGrin
#1006 Posted : 16 April 2013 00:48:11
Hi Jase, thank you for the kind commentsBigGrin Best wishes Mike
#1007 Posted : 16 April 2013 10:09:11
BigGrin Hi Mike
looking good, there's more small detail on her than I expected
Gaz
#1008 Posted : 16 April 2013 12:03:17
Looking good MikeBigGrin.
You are at about the same stage as myself. How did you find painting the small white metal bits? I found that for the primer to take I had to give them all a good rub down with some very fine wet and dry paper to remove any manufacturing residue.
Gareth
Completed models,Hachette Titanic.Deags. Hms Victory. Hachette Hems Hood.Ongoing builds. Deags Akagi,Deags Sovereign of the Seas,Deags Spitfire,On my wish list.Yamato.Royal Navy world war 2 aircraft carrier.
#1009 Posted : 16 April 2013 12:26:19
Gareth
Hi Gaz Thank you for your nice comment.I did not use primer I clean all the parts with nail varnish remover and apply two coats of paint by brushBigGrin I hope that helps you
Kind regards Mike
#1010 Posted : 16 April 2013 13:26:02
Hi Mike.
Looking very nice. The detail is starting to show on the bulkheads.
Looks very impressive.
IanCool BigGrin
Jesus-Belzheim
#1011 Posted : 16 April 2013 16:25:28
You`re doing great Mike, nice work ThumpUp
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
#1012 Posted : 16 April 2013 20:24:33
arpurchase wrote:
BigGrin Hi Mike
Hi Andy there certainly isBigGrin thank you for looking in and your nice comment. Kind regards Mike
#1013 Posted : 16 April 2013 22:20:54
Hi Peter, thank youBigGrin how are you? kind regards Mike
#1014 Posted : 16 April 2013 22:33:52
This is coming together very nicely Mike, high standard as usual....BigGrin BigGrin
#1015 Posted : 17 April 2013 00:18:19
Hi Alan Thank youBigGrin kind regards Mike
#1016 Posted : 17 April 2013 21:31:24
ISSUE 70 AND 71
Hi this time I am putting some final touches to these issues, the photos should explain all, watch for the Port and Starboard additions to the centre deck and the 6 round dowal supports which will support the next deck (which believe it or not will cover all the detail I have just finishedBlink
court orchard
#1017 Posted : 17 April 2013 21:38:27
Excellent work Mike.
I thought for a second that those were Toilet Rolls and you were modelling the HeadsLOL
#1018 Posted : 17 April 2013 21:39:21
Huh This is the deck that now covers all the detail. thats all for now, Kind regards Mike
#1019 Posted : 17 April 2013 21:41:22
Fantastic work Mike! Will you be weathering or a clean build?BigGrin
#1020 Posted : 18 April 2013 08:28:14
Hi Andy thank you for your nice commentsBigGrin you could be right, kind regards Mike
Guest (5)
This page was generated in 0.336 seconds.
