Query Options
jpda
#1 Posted : 16 April 2013 16:31:34
Rank: Beginner Level 3
Red Medal: Red Medal
Hi again.
Just looking at some of the builds. I've noticed planking done on the 2nd deck? Is this an optional addition to builds or still to be done in later issues? Is this planking the same wood dimensions of the hull planking?
Thanks again
Jay
#2 Posted : 16 April 2013 16:37:14
Its not in the instructions and is down to personal choice, but dont use similar to the hull planking as its way too thick.
Experienced builders tend to go their own route with adding enhancements or changes to the intended build.
jpda
#3 Posted : 16 April 2013 17:22:48
Thanks Tomik.
Any more progress on your build
Thanks
Jay
#4 Posted : 16 April 2013 18:42:41
Just for you... BigGrin
jpda
#5 Posted : 16 April 2013 21:29:48
haha. nice 1.
coming on nicely.
Captain David
#6 Posted : 16 April 2013 22:43:58
Some builders have been planking the second deck, as a practice run at techniques of construction and finishing.
I don't think any of the second deck will be visible on the finished model, if done as per the official build.
If you are going for some lighting on the gun-decks, this planking might just be visible through the deck gratings, if you decide to cut the upper deck out under the gratings. You would have to really squint at it from directly above to see anything though. This would be a modification to the official build - up to you.
#7 Posted : 17 April 2013 08:12:39
BigGrin Hi jpda I did some on mine just for the practiceLaugh
jpda
#8 Posted : 17 April 2013 12:01:25
Thanks for clarifying guys.
Looks good martyn.
Regards.
Jay
#9 Posted : 17 April 2013 14:38:54
BigGrin Happy to help.Good luck with the build BigGrin
This page was generated in 0.100 seconds.
