Hi all, Just received parts 6-10 and was about to set up my jig for the keel and realised that the bow section of the centre keel is not only out of flat but also twisted laterally. I have tried once to flatten the problem but it seems to have gone back to it`s old shape.This being the case is there anything else I can try or do I need to get a back issue,or can I get a replacement part? My previous attempt to straighten the piece was done by soaking the part and then clamping between several bits of 3"x3" wood blocks, this was then clamped using large metal sash cramps and left for two days but to no avail. Any Ideas, Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Might be best to just call or mail costumer service. They will probably send you a replacement part.
Greetings Lucien
 Hi Delboy Faulty of broken parts are usually replaced free of charge the best way to do this is to ring up between 9 am-5pm during the week. Make sure you have your details with you aswell. Hope this helps regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi, Thanks guys, I`m off work for a couple of days, so will contact CS and see what they can do. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
