broken parts Options
yorkieboy1
#1 Posted : 26 May 2010 13:27:39
have had an accident with the launch snapped the keel in 3 pieces have tried to reorder issue part6 but cannot even get into the shop area has any one any ideas
Mike Turpin
#2 Posted : 26 May 2010 13:51:12
Hi Yorkieboy
If the pieces cannot be joined together, how about using them as a pattern and cut another keel from the waste material that you should have left over from the launch parts? This is the joy of working in wood and I would think more satisfying and certainly cheaper than going to the trouble to re-order issue 6.
Mike T
#3 Posted : 26 May 2010 13:57:45
Hi Yorkieboy and welcome.
i was in the same boat (no pun intended) as you. I snapped on of my formers, so i ordered a back-issue on line on their website.
Just another option
dedworthdog
#4 Posted : 26 May 2010 16:03:37
You could phone customer services Number in the mag
Follow my build to learn how to make firewood
Son of Bulwark
#5 Posted : 26 May 2010 17:11:08
Hi yorkieboy1! BigGrin
Mike Turpin is right make a replacement part, it's mad to buy another issue for 1 broken part. If you don't have a large piece of scrape you can buy sheets of ply from 0.4mm up and in different types of wood from cornwall model boats link is below:-
http://www.cornwallmodel...k/acatalog/Plywood.html
I like to buy the odd sheets when placing an order it come in handy at times!.ThumpUp
budgie
#6 Posted : 26 May 2010 18:58:23
Blushing hi ordered last night #6 & #1 as only 1.99 for xtra canon & glue
so i will have spare keel if u want it
yorkieboy1
#7 Posted : 26 May 2010 22:08:07
thanks all of you for your input Mike T has hit the nail on the head have managed to glue the pieces together and made another template but will also take budgie on his offer once again many thanks
budgie
#8 Posted : 26 May 2010 22:18:43
BigGrin hi Yorkie i pressed email button & sent my address Confused hope u rcd it
