Finishing the hull Options
RobT
#1 Posted : 13 April 2013 22:03:06
Does the magazine include any steps on finishing the hull, such as sanding and filling, or is it just something that you do yourself if you need to?
If so, is the best time when you complete the hull and before you start putting the upper strakes on, or is there a better time?
#2 Posted : 13 April 2013 22:13:27
It does indeed Rob, but nothing on filling which will vary from one build to another.
Admiral Anti Spiral
#3 Posted : 13 April 2013 23:11:40
i found it a bit hard to sand down the curve but i guess it depends on the sanding tools you have.
Processing - Progressing
Previous builds: HMS Victory
RobT
#4 Posted : 14 April 2013 00:30:28
As it's my first planking, it will need some work, but I've armed myself with a mountain of tools. Dremel, mouse sander, sanding blocks, files. You name it I've got it.
Will spend a long time making sure it's right.
#5 Posted : 14 April 2013 00:35:23
Rob, some photo's of your progress would help others give constructive advice...... It would serve to help you ensure your build is a successful one..... Help us to help you....
benny b
#6 Posted : 15 April 2013 19:27:52
remember rob dont sand to hard you can take away but it,s puting back thats the problem
This page was generated in 0.083 seconds.
