 Hi All This months construction is now all done, well the major platforms have been added ,there are still some machine guns, binoculars to be added but at a later date as right now there just bits to knock off and lose. The upper platform needed the most fetteling to get to fit correctly the others more or less fitted from the pack apart from the removal/ rebating of the braces on the undersides so they slid into there correct positions. As usual all comments/questions are welcome. regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looking great Andy... Had to look twice at your pics.... thought you were trying to introduce some battle damage there with the pealing and warping of the deck's until I realised it was masking tape...  .... well done.... keep posting... Regards Alan
 Hi Alan thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Rank: Vice-Master       Groups: Registered
Joined: 21/04/2012 Posts: 747 Points: 2,233 Location: Tokyo, Japan
Hi Andy! I think that your building is going well and it is the same as another Akagi of 1/700. I guess you make this hanger deck be just put but not glued, because you still have to attach the anchor chains and other parts under this module. An order of an assembly is especially important to make such kit. Please be careful to the position of seven supports of the hanger deck. DeAGOSTINI Japan showed us wrong position of these supports. Best Regards, Yutaro DeAGOSTINI 1/250 the YAMATO, 1/250 the AKAGI. Hasegawa Co. 1/350 Battle ship NGATO, 1/350 Aircraft carrier Akagi, Battle ship MIKASA. Water line series 1/700 Battle ship YAMATO, HIEI, YAMASHIRO, Aircraft carrier HIRYU,TAIHO, Heavy Cruiser Myoukou, Ashigara, Nachi, Haguro & others.
 Hi Yaturo Thanks for looking in and yes your right the hangar isn't glued down just yet as there is still quite a bit to do in this area as you say. Also I had noted your previous posts about the position of those struts and will make the appropriate changes as nessesary regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Im a little behind with the Akagi as im consentrating on finishing the Yamato at the moment, posts will resume shortly regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 14/03/2013 Posts: 43 Points: 129 Location: Calwell ACT AU
Looking very good Andy.....Phil You only live once, but if you work it right, once is enough.
Building - Bismarck, Akagi, Warspite, Gato, USS Enterprise (carrier) and D51
 Hi thanks for looking in Bluedot Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy are you going to be weathering her or displaying her 'scrubbed up'? “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Hi Jase Not sure as yet still thinking on it, she had been around for a while though so she always looked a little grubby Andy PS sorry its taken a while to answer not been to well 4 the last week Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All finally got back to the Akagi build only 2 months behind now  but as its mostly top decks to make up it wont take long to catch up. Today I made up the bow deck and attached the network of girders underneath regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looking good Andy, nicely done as usual..... Regards Alan
 Hi Alan Thanks for looking in Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy! Welcome back to the AKAGI from the YAMATO. Your truss structures are painted fine as usual. Best Regards, Yutaro DeAGOSTINI 1/250 the YAMATO, 1/250 the AKAGI. Hasegawa Co. 1/350 Battle ship NGATO, 1/350 Aircraft carrier Akagi, Battle ship MIKASA. Water line series 1/700 Battle ship YAMATO, HIEI, YAMASHIRO, Aircraft carrier HIRYU,TAIHO, Heavy Cruiser Myoukou, Ashigara, Nachi, Haguro & others.
Joined: 20/10/2010 Posts: 511 Points: 1,459 Location: Loughborough
Looking good there Andy. Keep up the good work. Builds in progress: HMS Victory.HMS Surprise. Completed builds: Revell London Bus 1/24. Builds to do:Sovereign of the seas, Hms Albion.
Hi Andy, looking good as usual.....Phil You only live once, but if you work it right, once is enough.
 Hi Phil Thanks for your comments sorry iv not got back as soon as I would have liked but iv been in hospital, on the mend now so things should pick up again regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote: Hi Phil Thanks for your comments sorry iv not got back as soon as I would have liked but iv been in hospital, on the mend now so things should pick up again regards Andy Andy, sorry to hear you have had a spell in hospital, really hope you are well on the mend now and able to get back onto your builds....  .. Sincere best wishes to you..... Regards Alan
Hope you are feeling much better Andy,don't worry about the builds your health matters. Get well soon. Builds in progress: HMS Victory.HMS Surprise. Completed builds: Revell London Bus 1/24. Builds to do:Sovereign of the seas, Hms Albion.
 Hi Peter and Alan thank you for your kind words, im on the mend now but they still don't know what caused the problem regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
