Tony's Tamiya Electric Handy Drill Options
#1 Posted : 05 April 2013 14:02:32
Maybe a slightly odd item to include in the finished build section but as this started out as a "Model Kit" I hope this is acceptable as it does not appear to fit into the Members Ship Build Diaries.
Also hoping that this might get me one of those "Completed Build Medals" (Hint Hint Admin Blushing ).
I do have a dremel and subscribers of the SotS series receive a mini electric drill so what, might you ask, is the point of buying this product.
In my case I have been struggling lately using the "manual" pin vices and to be honest while a dremel is very good its far too powerful to use with micro drill bits, and in most cases it’s too much effort to run an extension cable and plug the thing in.
Hence a decision to but one of these Tamiya drills. I purchased this via eBay as a new item from Hong Kong on 27th March and received it yesterday (04/04/13). It cost me £11.00 but had a £6.50 postage cost so quite expensive. Did some scanning for UK suppliers but the few I found would have seen me spending even more on the item (guess this is where someone will write back with a "Did you know you could have got it for this" BigGrin
The drill comes with two collets that allow the use of 1mm to 2mm and the second collet allows 2mm to 3mm drills. Having had a little play I have found that the smaller collet actually allows micro drills down to 0.5mm to be used.
With this item there is absolutely no soldering or gluing required. Tamiya thoughtfully include a couple of spare washers and circlips as these are quite tiny and could be easily lost when doing the build.
Hopefully the following pictures will give you some idea of the construction sequence and the end result is a "Finished Build".
Happy to be "pulled up" by ADMIN if I have posted this in the wrong location or if the article is deemed inappropriate.
Hope you enjoy.
Kind regards
#2 Posted : 05 April 2013 14:22:16
I like this, i dont always feel like getting the dremmel out either so a battery drill would be handy - does the speed increase with pressure on the trigger or is it fixed?
#3 Posted : 05 April 2013 14:41:48
Hi Steve
Its a fixed speed drill rather than variable.
Cannot find the torque setting details anywhere but quite a powerful little unit for just 3 volts of battery.
The instructions state that its only really suitable for wood and plastic which is fine as that is all I use micr drill bits on anyhow.
Kind regards
jonny7england
#4 Posted : 05 April 2013 16:59:55
Hi there Tony..Its a great build mate..I saw one on Amazon for sale at £16 but there was only one in stock, but I shall keep an eye on it to see if they get any more? Thanks for the heads up on the drill...
Wink ThumpUp
#5 Posted : 05 April 2013 19:29:11
Jonny/Andy
Thanks for your kind comments/updates.
Happy with my purchase as it does seem to work very well (just a bit miffed still about the price but I guess this is the same on all far east kits. Been looking at Hasegawa 1:48 and 1:72 plastic kits recently and cannot believe how they have gone through the roof).
I will be 50 very soon and already have all the aches and pains that are telling me to retire - oh well only another 15 years (at best) before that happens - ha ha
Kind regards
#6 Posted : 05 April 2013 19:47:52
That's brilliant!
Is there anything these people can't turn into a construction kit?Blink Blink
Thanks for this great post!
Robin
#7 Posted : 05 April 2013 20:27:02
Confused Confused i dont get it - is it a tool or a model Confused Confused
Glen
#8 Posted : 05 April 2013 20:32:00
Flapper Quicker to build the VICTORYLOL LOL LOL LOL
Roger the Cabin Boy
#9 Posted : 05 April 2013 23:21:27
Hi Jase, why can't it be both.... BigGrin BigGrin .. Think its a great little model/tool..... Nice one Tony.....BigGrin BigGrin
#10 Posted : 06 April 2013 11:00:47
Good day to everyone.
Sorry if I caused any confusion but just to confirm this is an actual tool that you have to build yourself.
I will admit its an odd concept and not quite sure why Tamiya adopted this approach - maybe having to build it yourself keeps the costs down?
Kind regards
#11 Posted : 06 April 2013 12:31:23
Kind regards
Hi Tony, it is my understanding that the import duty is less on a kit,(CKD complete knock down) than a complete unit.
I may be wrong on this one, anyone got any thoughts?
Kind regards
Mike
#12 Posted : 06 April 2013 12:45:59
Hi there Mike and Tony.
You might have something there in the import duty thing Mike, I personally think that the Japanese and especially Tamiya who have been 'at it' for decades simply have a great love of turning anything into a construction kit!
It's a wonderful concept, not only does the modeller get to say I built that but also and I built the tools that made it!BigGrin
It would be great if they could produce kits to make your own wood lathe, 'proper' mini router (ie a bench type) and even a dedicated sail stitcher!Drool
Best Wishes
Robin
This page was generated in 0.176 seconds.
