Love it Robert, so neat, clean and tidy.... very well done..... Regards Alan
Joined: 20/10/2010 Posts: 511 Points: 1,459 Location: Loughborough
Really nice build there Robert, your doing a grand job. Builds in progress: HMS Victory.HMS Surprise. Completed builds: Revell London Bus 1/24. Builds to do:Sovereign of the seas, Hms Albion.
Joined: 25/01/2010 Posts: 459 Points: 1,367 Location: Bridlington
Joined: 02/04/2013 Posts: 174 Points: 534 Location: Bethlehem PA, USA
I think the dimensions are what you think is best. That's my attitude. If I question it I generally try to answer it myself. (Since I'm the one who has to live with it). But it looks like you're doing a very nice job. Those gratings and capstan handles are a lady. It takes a lot of dedication and discipline.
Thanks' you guys, My second attempt. Looks a bit rough going to clean it up a bit. Regards
Rob
Bridlington.
Built Flying Scotsman (Train). Collecting HMS VICTORY
Looks good to me Rob, think your work is first class..... Regards Alan
Good clean build there, Rob. Well done. Had me going for a moment with your first pic, but all was revealed further down. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
 Hi Robert It looks to me[ but it may be the illusion caused by the pic] that you have 3 sizes or matching pairs there, the centre 2 look about the same size, then working outwards each way 3 and 4 seam to match as do 5 and 6 so you may be able to do something with them using them as pairs [5,3,1,2,4,6 as you look at your pic] Hope this is of help Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote: Hi Robert It looks to me[ but it may be the illusion caused by the pic] that you have 3 sizes or matching pairs there, the centre 2 look about the same size, then working outwards each way 3 and 4 seam to match as do 5 and 6 so you may be able to do something with them using them as pairs [5,3,1,2,4,6 as you look at your pic] Hope this is of help Regards Andy Hi thanks, I have tried that but I need 4 the same and two the same, not only that the holes are not all central, and it makes the work look Regards Rob. Regards
Rob
Bridlington.
Hi I need help with the Ships rudder wheel, does anyone know where I can find part 207 rudder wheel shaft 3x7, and part 208, central separating axil 3x7 Walnut.
I don't want to cut any dowels as they my be part of the masts, lolRegards
Rob
Bridlington.
Hi Robert the parts your looking for are made from some of the 3mm dowel you were supplied, these also make up parts of the masts but at 7 mm they supply the doweling over length anyway so you should be ok. Hope this helps. Builds in progress: HMS Victory.HMS Surprise. Completed builds: Revell London Bus 1/24. Builds to do:Sovereign of the seas, Hms Albion.
I made my own since I personally think the 3mm is way too thin. I went in at around 6mm which seems to be more to scale. I'm at the point where I don't follow the kit instructions any more other than as a reference. I go by photos of the Movie ship and make my best guess. So far it looks a lot better than following the directions.
Looking fantastic “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Lovely finish on those rails Rob, very well done..... Regards Alan
Nicely done on the rails Rob. Keep it up. Builds in progress: HMS Victory.HMS Surprise. Completed builds: Revell London Bus 1/24. Builds to do:Sovereign of the seas, Hms Albion.
Joined: 06/05/2010 Posts: 233 Points: 708 Location: Leigh on Sea
Robert you are the new Magpie H.M.S Victory H.M.S Victory X Section H.M.S Surprise under the bench D-51
