Plank described on page 115 in the Instructions. Options
dbartonjr
#1 Posted : 03 April 2013 09:57:18
Hi all,
I have a problem, it appears that I am missing one plank, described on page 115. The plank is triangular and divided into 2 75mm and 2 50mm segments. They are glued to both sides of the rudder. I have 2 questions:
Does anyone know where I could purchase a plank with dimensions of approximately a=7mm, b=6.5mm, or c=9mm.
What package did the plank come in, I think 9 but I would like confirmation.
Thanks again for your help.
Dan Barton
Current Builds: Yamato
On the Bench: Akagi, USS Missouri
#2 Posted : 03 April 2013 16:09:16
Its in parts set 39.
If you pop along to a local model shop which stocks balsa, you will likely find a similar or larger triangular section which can be cut down, or simply request a replacement parts set 39 via C/S
#3 Posted : 03 April 2013 20:21:20
BigGrin Hi db
The part your after came with the previous pack of 4 sets of parts and it say's to put aside until later[ or words to that effect]. As Mr T has said a local model shop will have the triangular balsa but try to get medium/soft density not the rock hard stuff as you will need to sand this to profile. Another way that you might try is to use filler for this section. Hope this helps
