Be gentle... Options
Oli
#1 Posted : 03 April 2013 03:50:19
Rank: Newbie
Quick hello. New to the forum and pretty much new to model building in general (unless Kinder eggs count?). Always wanted to build something like this one day though and I'm pretty good with my hands, or so the ladies tell me BigGrin , so why no jump in at the deep end?
Up to issue 13 now and so far so good but I've hit a little snag. I'm planking the launch and I'm not happy with the finish. I'm going to cut some more of my own little balsa wood strips and start again because the problem I have is with bending the strips without breaking them up by the stern? Or is it the bow? Huh I mean the front bit lol. Any tips? I'm thinking maybe if I try to soften them by moistening them a little with water?
Thanks in advance for any help you can offer Cool
Hans
#2 Posted : 03 April 2013 08:50:36
Hi Oli and welcome aboard. Many things can be learnt on the forum. Best is to soak the plank a little, attach and leave overnight to dry. If you have a soldering iron handy you can use that, just be careful not to burn the wood or yourself, or alternatively a plank bender will also do the job. Hope this helps.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
Dontshootme
#3 Posted : 03 April 2013 10:57:26
Hello & welcome Oli,another way of bending the launch planks without soaking etc is to grasp them fairly tightly between thumb & forefinger nails & pull the plank though several times until the desired bend is achieved,you can also put a twist into the bend by altering the direction of pull.Hope this helps.
#4 Posted : 03 April 2013 11:06:48
Hi Oli a big warm welcome to the Model Space ForumBigGrin You can achieve the bend of the planks with the methods Hans and Rob have mentioned, you can also hold a plank in tweezers over the spout of a boiling kettle, then as Hans suggests fit it damp without adhesive and when it is dry the shape remains, I hope that helps Kind regards Mike
Admiral Anti Spiral
#5 Posted : 03 April 2013 14:06:25
Welcome oli, just like to say your kinder egg joke cracked me up, and i agree with the others, the planks are quite thin so best not to soak them for too long, good luck with your build!
Processing - Progressing
Previous builds: HMS Victory
Oli
#6 Posted : 03 April 2013 17:28:48
Rank: Newbie
Thanks for the tips guys. Much appreciated :) I think I'll order a back issue to get some more planks and give it another whirl. I knew I was doing something wrong. All part of the learning process though :)
BTW anyone else had a little trouble with the subscriptions? I've been sent two No.18 issues and no No.14. Irritating? Just a little. Grrr...
RobT
#7 Posted : 03 April 2013 18:32:42
Hi Oli,
Also as the planks are so thin, a normal plank bender will just break them, so stay from that for the launch, but they are fine for the main planking on the ship.
#8 Posted : 03 April 2013 20:24:43
BigGrin Welcome aboard OliCool
#9 Posted : 03 April 2013 21:19:44
Welcome to the forum Oli Cool
budgie
#10 Posted : 03 April 2013 21:43:34
BigGrin Hi Oli try this link hope it helps
http://www.model-space.c...ictory-the-launch-build/
#11 Posted : 03 April 2013 22:07:38
A very warm welcome to the forum Oli, am sure you find all the information you need here.... Look forward to seeing your work...BigGrin BigGrin
Oli
#12 Posted : 05 April 2013 03:04:35
Rank: Newbie
[quote=budgie]BigGrin Hi Oli try this link hope it helps
http://www.model-space.c...ctory-the-launch-build/[/quote]
Great link BigGrin Much appreciated. Where I went wrong was trying to fit th e strakes without moistening them first. Broke the first two. Cursed a little. Tried again. Wood glue wouldn't hold. Cursed again. Opened a beer. Tried again. This time I used superglue to hold the beggars in place. That actually worked lol Not sure Admiral Nelson would have approved the final result though. I think the kindest thing I can say about it is that it probably wouldn't sink. Well...not immediately anyway.
Thanks to everyone else for the warm welcome and all the other tips. :)
sapuna
#13 Posted : 10 May 2013 15:47:43
Rank: Newbie
hi guys I'm IN SAME BOAT OR SHIP LIKE OLI.
THIS FORUM IS VERY HELPFUL. THANK YOU FOR YOUR IDEAS
#14 Posted : 10 May 2013 15:49:15
Welcome Sapuna Cool
stujue
#15 Posted : 10 May 2013 16:30:58
Hello Oli Hello Sapuna
I also had an issue with the launch as this is my first attempt at this kind of model. Was pretty good at the Kinder stuff though. The advice you get on here is second to non and everyone is very willing to help. My advice with the launch is dont make the mistake i did by over sanding the outside. i ended up having to re order issue 8 and start again. it also initiated me to the forum and got some good advice.
Cheers
Stu
Cheers Stu
Captain David
#16 Posted : 10 May 2013 18:05:43
Hi Oli
I bent the launch planking just by dipping the ends in a glass of cold water for 15 minutes, then take out and stroke gently between your fingernails to get a bit of a curve, then soak again and repeat if necessary. Then pin them around something like a wine cork and leave to dry.
I am only up to issue 9 and there was enough planking to finish the job with two strips spare. I think I will get some more planks with issue 10 and don't know why they are needed.
This page was generated in 0.138 seconds.
