keeping the ribs square Options
wallace
#1 Posted : 23 May 2010 21:35:47
hi all, i just wondered if someone out there could help. obviously the ribs will need to be square when glued to the keel so i was wondering what would be the best way to do this and if there is a tool out there that could help.
Zeptrader
#2 Posted : 23 May 2010 22:12:56
Hi, if you check the 'Index of Post' in my sig (bottom of this post)you will find a list of previous post's (there are many) regarding this topic.
But in short use metal brackets found at most harware shops, make sure they are square first before buying.
cliffweld
#3 Posted : 23 May 2010 22:15:56
Hi Wallace,i use right angle metal brackets that you can get from any hardware store and clamp the ribs to the keel frame until the glue dries.
CURRENT BUILDS
HMS HALIFAX
HMS BOUNTY
LYDIA EVA(STEAM DRIFTER)
MANTUA COASTAL CANON
COREL VICTORY CROSS SECTION
TAMIYA 1/35 MATILDA MK 2
HACHETTE TIGER TANK
DRAGON 1/35 TIGER TANK
budgie
#4 Posted : 23 May 2010 22:18:30
BigGrin hi wallace is this for main keel or the launch
check out build diarys for making a jig to keep the keel level
i would ensure work bench is level with the use of a spirit level
then when placing keel between brackets check by using an engineers square
then u can use right angle brackets clamped to the ribs and keel while glue dries but check check check they are at correct angle again using eng square
i think a picture tells a thousand words so best to check build diaries for clarity
(Crying i should learn to practise what i preach)
sure some of the other guys will post a clearer description or other methods tried & tested
tomo29
#5 Posted : 24 May 2010 14:09:21
thats what i a going to use
#6 Posted : 28 May 2010 22:08:03
yep here's an easier way (put that bit on there,check once, then screw that bit here, that's it, and glue this piece to that bit and all square.)
budgie
#7 Posted : 29 May 2010 11:22:15
Crying another dig at me????
jonny7england
#8 Posted : 29 May 2010 11:54:23
Here's an idea lads, and using those angle brackets, I have purchased some one inch angle brackets, and checking that they are perfectly forty five degree angle, I was considering clamping these to the keel to get the perfect rib alignment? If somebody has already come up with this idea, I apologise...BigGrin
Pilgrim
#9 Posted : 30 May 2010 22:47:45
Rank: Amateur level 2
Somehow I'm not convinced 45 degree angle brackets are going to give you the result you're looking for.
This page was generated in 0.121 seconds.
