Joined: 20/01/2011 Posts: 608 Points: 1,753 Location: Canberra, Australia
First photo of lots. Opened the section with the wood in it, to check the fit of the parts, which was very good.
The Victory's 12lb cannon. Needs some yellow ocher paint on on it, this can wait until I'm actually building the Victory.
Anchor for the HMS Victory, sitting on the HMB Endeavour.
A bit more work on the Victory. The paints in the back right corner are admiralty paints for the Endeavour.
Latest bit of work on the Victory.
HMS Victory as she is now, with the start of the HMS Hood off to one side.
Lighting in progress on the next deck up.
 Rank: Pro   Groups: Joined: 04/05/2012 Posts: 362 Points: 1,089
A nice start Skyfire I just hope you don`t get problems later on, your keel is not srtaight
It's straighter than it looks, also the front section is only just sitting there and is not glued in at that point.
It`s ok when it`s straight It just didn`t look straight to me I just wanted to warn you Now you would stil be able to change it, after the planking it`s to late
Also any bend in the hull has straightend itself out once the two decks were in place.
