10 Pages <1234>»
moriarty,s HMS Victory renovation project Options
moriarty
#21 Posted : 25 March 2013 15:50:32
Spent a couple of hours wit a rasp and tore down the ribs and got everything flat. The original plan if I remember said to attach the cannon to a little block of wood and insert through the gunport!. I think this way will work better and more solid.
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
#22 Posted : 25 March 2013 21:34:10
Wow Moriarty, didn't take you long to strip her down to her bare shell..... Look forward to seeing how this project turns out....BigGrin BigGrin
moriarty
#23 Posted : 26 March 2013 14:28:19
First line of gunports are now in after a lot of measure and debate exactly where to put em
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
moriarty
#24 Posted : 26 March 2013 14:32:59
I encountered a little problem with the bow shape in that it wasnt right and the planks would not sit right. On looking through some of the builds ,I decided to put in extra formers to try and correct this. At first glance it seems to work. I can see the benefits of fitting all them balsa formers.
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
moriarty
#25 Posted : 27 March 2013 00:19:05
It seems to be working.
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
#26 Posted : 27 March 2013 00:49:38
Got to admire you for attempting this, so much more work involved than just starting a new build, looking very nice in that last pic though, will be watching this one all the way BigGrin
moriarty
#27 Posted : 27 March 2013 19:43:14
Another update on her. Gunports all in on the port side.
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
moriarty
#28 Posted : 27 March 2013 19:47:00
New decking in the process of fitting. I decided this had to go in now to add stability to the walls and it would not have gone in later as I intended. Ready to start the starboard side now. Progress will be slow now as I am back to work after a wek offBigGrin .
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
#29 Posted : 27 March 2013 21:07:09
Hi Moriarty.
You're really cracking on with her and improving all the way! It's really interesting seeing your Mantua version 'naked' Blushing and comparing her with the DelPrado early stages in the kit build instructions, almost identical sized models but so many differences in the methods and kit parts!
Keep up the good work M Cool
Robin
#30 Posted : 27 March 2013 22:09:36
You don't hang around Moriarty, will say that for you... Cracking work and can see the renovation will be a big improvement..... Enjoying following your work on this..... BigGrin BigGrin
moriarty
#31 Posted : 02 April 2013 00:46:47
Another update on progress. Got this deck in and the walls done.
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
moriarty
#32 Posted : 02 April 2013 00:49:36
All the lower gunports are now cut and the bullwarks are going in on the starboard side.
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
moriarty
#33 Posted : 02 April 2013 00:50:42
And a rear view.
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
#34 Posted : 03 April 2013 00:07:32
Classy work Moriarty, can see this will end up being a renovation to be proud of.... Keep posting the good work....BigGrin BigGrin
moriarty
#35 Posted : 03 April 2013 01:02:26
Cheers Alan, another update. I had to cut in the drips for the gunports so here they are.
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
moriarty
#36 Posted : 03 April 2013 01:05:42
I still had the original brass drips that I never fitted on the original. Held on to them for 10 years, never throw anything away. A dry run with the doors and drips as they will look hopefully.
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
Hans
#37 Posted : 03 April 2013 09:23:50
Beautiful work there Moriarty. She is going the real classy way I think. Watching with interest
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
Virtue86
#38 Posted : 03 April 2013 16:29:23
Looking very very good and i look forward to seeing further posts
Cheers
Peter
[b]Built:1:250 Titanic
moriarty
#39 Posted : 08 April 2013 12:47:17
Another update guys, had a think about the stand for this one and decided to build it in with the hull.The hull is going to be coppered so it should all look neat and tidy when finished. A couple of bits of scrap dowl cut into the keel and anchored with a smaller piece, abit of glue ,a couple of pins and it is rock solid.BigGrin
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
moriarty
#40 Posted : 08 April 2013 12:48:22
This is how it looks on the finished side.
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
Guest (9)
10 Pages <1234>»
