Japanese battleship Shikishima
 Well done Nemesis  How did u get that so quickly  Over to you
Oooops sorry peeps!! Ok a three part question! When was the first "Steel-Wheeled" Tiger produced, what chassis no. and what happened to it?
January 1944 is when the steel wheel version rolled of the production line could not give the other details though “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Sorry Jase, miles off with the year!!
Oh are we talking prototype ? Or is this a tricks question as in all tigers had steel wheels lol “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
No trick!!  The first tiger with all steel wheels!!
Chassis No. 250822 - it was built in 1942 and was confiscated by Wa Pruf 6 for testing?
Kev
Correct again my friend, over to you!!!
The Germans developed a late WW2 tracked vehicle to specifically knock down reinforced buildings and bunkers when attacking Russian cities. It utilised the hull and running gear of an existing German tank and carried a heavy mortar which was originally designed for a different branch of the German Armed Forces.
1. What was the name of the vehicle? 2. What tank was the hull and running gear taken from? 3. What branch of the German Armed Forces was the mortar originally designed for and what was its' main purpose in that Force?
Kev
It is the Sturmtiger, based on the mid and late Tiger 1 chassis. The mortar was originally designed for the German Navy as a submarine destroyer, there was also talk that a shell from this rocket launcher sank HMS Hood, although later proved to not be correct.
Spot on Daran, well done mate and I knew you'd be the first to get that one!!
Don't think there were very many submarines in Stalingrad though were there!!??
Your go my friend?
Kev
In 1945 the Russians experimented with some bolt on armour on a T-34/85 against anti-tank rockets. What was the armour, and what was the outcome of the first test infront of their high command????
Without having the faintest idea, I'd theorise that the armour was composed of captured SS Officers and that subsequently the Russian High Command decided that using an 18" Naval Shore battery probably wasn't the most realistic of demonstrations! Good question though! Robin First wooden ship: The Grimsby 12 Gun 'Frigate' by Constructo Second: Bounty DelPrado Part Works Third: HMS Victory DelPrado Part Works 1/100 scale Diorama of the Battle of the Brandywine from the American Revolutionary War Diorama of the Battle of New Falkland (unfinished sci-fi), Great War Centenary Diorama of the Messines Ridge Assault Index for the Victory diary is on page 1
Plymouth57 wrote:Without having the faintest idea, I'd theorise that the armour was composed of captured SS Officers and that subsequently the Russian High Command decided that using an 18" Naval Shore battery probably wasn't the most realistic of demonstrations! Good question though! Robin Ahahahahaha!! I wish that was the answer!!!!!!
Ahem .... it seems that Daran is not keeping an eye on his quiz questions, that's all three quizzes!!
Come on man, chop chop, otherwise you'll be on potato peeling duty!!
Kev
Joined: 20/10/2010 Posts: 511 Points: 1,459 Location: Loughborough
The only thing I have found about the armour updates was this late one from 1945 spring. The additional screening consisted of a thin, 1.5 mm, metal plate or a 3 mm wire mesh welded on the supporting corners. The shield was placed in 15-20 cm from the main armor on the sides of the hull, turret and the turret's top. Couldn't find out about the test you got me there  . Peter Builds in progress: HMS Victory.HMS Surprise. Completed builds: Revell London Bus 1/24. Builds to do:Sovereign of the seas, Hms Albion.
Guest (12)
