Hi All  , Have what may be a minor problem(I hope),by the end of issue 24`s planking my lower and upper planks will meet at the bow, but in the mag instructions there is still a gap after the planking of issue 25. I can only assume that I have not tapered the planks enough,so is this a case of removing planks and thinning then refitting, or, as this is only the base planking does it not matter? Ideas/comments welcome, Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Rank: Pro Groups: Registered
Joined: 05/12/2012 Posts: 258 Points: 754 Location: manchester
hi delboy i had the same problem but just kept going have finished hull now and it looks right same as you said i dont think it maters on first layer
 Hi Derek don't worry carry on planking it will work out ok as long as it is smooth . It will need filling anyway Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Martyn Ingram wrote: Hi Derek don't worry carry on planking it will work out ok as long as it is smooth . It will need filling anyway Cheers Guys Thought that was the case, just wanted to check  . Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
delboy271155 wrote:Martyn Ingram wrote: Hi Derek don't worry carry on planking it will work out ok as long as it is smooth . It will need filling anyway Cheers Guys Thought that was the case, just wanted to check  . Regards delboy271155 (Derek) Hi Derek, my build went the same way but if you have a look at my posts you will see how I just carried on to complete the first layer.... As long as it's covered and smooth then it won't be a problem after filling and sanding... Do need a good finish though before starting to apply the 2nd layer.... Good luck.... Regards Alan
