FITTING THE GALLERY SIDE PANELS Now to the meat of the project. I fitted a small fillet to the side panels (at the point where the hull shape goes in at the waist:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
FITTING THE GALLERY SIDE PANELS I prepared the tops of the Panels as supplied by De Ag and fitted them:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
FITTING THE GALLERY SIDE PANELS MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
FITTING THE SIDE GALLERY PANELS The tops of the Panels are dry fitted because I have alot more work on my Victory to do before I fit them permanently. Well thats all for this session, next time I will be fitting the Ballustrades in brass. I will leave you with photos of this finished session  Kind regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi mike. Looking fantastic. Nice touch with the extra planking. Looking forward to seeing more of your build . Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Top job Mike looks terrific j “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Beautifull job ther Mike. Watching with interest. Well done Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Thank you Spence,Ian,Jase and Hans for your nice comments all appreciated  Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Rank: Pro   Groups: Joined: 04/05/2012 Posts: 362 Points: 1,089
Hi Mike Your Gallery looks fantastic And thank you for the step-by-step instructions  I`ll need them as soon as the copperplates are on the Hull Some day I will finisch it
Jesus-Belzheim wrote:Hi Mike Your Gallery looks fantastic And thank you for the step-by-step instructions  I`ll need them as soon as the copperplates are on the Hull Some day I will finisch it  Hi Peter, thank you for your comments, you are very welcome  Keep up the good work. your parcel is on the way to you. Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
PREPARING THE GALLERY ENHANCEMENT BRASS ETCH Hi again, the first job is to cut all the pieces from the brass fret, please use a sharp knife. Then with a file take off the burrs where the parts have been attached to the Fret:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
PREPARING THE GALLERY ENHANCEMENT BRASS ETCH Here are the parts for the stern panel and side panels:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
PREPARING THE GALLERY ENHANCEMENT BRASS ETCH Next we offer the parts to the ship and in each case form the shape of the brass etch to the curve of the particular panel it is being fitted to, being careful not to overdo it:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
PREPARING THE GALLERY ENHANCEMENT BRASS ETCH All the brass parts should now be prepared for painting, frist job is to remove all the grease by using Ladies nail varnish remover, please wear a mask and use outside as it has very strong fumes it is acetate. wipe all the brass with this then wash in warm soapy water. We can now spray our metal primer on the parts ----- but thats for next time. I will leave you with photos of the two products I have used. Thanks for looking in Kind regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi Mike. Look forward to seeing next instalment. Will probably do mine when coppering is done. Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
ian smith wrote:Hi Mike. Look forward to seeing next instalment. Will probably do mine when coppering is done. Ian. Hi Ian, I would prefer to do that to, but I have to support the members who have purchased the Gallery Enhancement (like yourself) and show them how it all goes together  Thank you for looking in, and for your nice comments  Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
The photo-etch looks good
Absolutely stunning mate..just love your work!! Can't wait to get back to my own builds.  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
jonny7england wrote:Absolutely stunning mate..just love your work!! Can't wait to get back to my own builds.  Hi Jonny thanks for looking in  your nice comments are much appreciated, I hope you get back to your builds soon  Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi Mike, your gallery enhancement is nothing short of exceptional..... am eager to see the finished product...... Very well done indeed...
Guest (10)
