 Rank: Pro  Groups: Registered
Joined: 24/01/2011 Posts: 206 Points: 614 Location: halifax
hi guys m in need of help after putting the poop deck the back end loks to reallyo ut of shap the ship as a whole looks to be straight but theres about 5mm differance from one side of the galley to the other the pics ive added are after i took off the panel (60) any suggestions what i can do to fix this problem thnaks cal cal attached the following image(s):
I'm affraid it looks like you will have to remove the gallery and remeasure the gallery location on the starboard sid e and even it up,I suggest you soak the gallery in warm water for ten minuets then carefully remove the gallery.allow 24 hours drying time,then redo after measuring.good luck. k. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Joined: 21/08/2010 Posts: 35 Points: 110 Location: Now in Berlin, Germany
...and parts will shrink in the drying process after soaking in water. I had a little surprise but observed natural process and corrected position as required to get a good fit. As I measured position I had to learn that planking on both sides is a little bit different - only a mm but trusted my eyes to find correct position. So, no easy task but with a second attempt you will succeed. best luck & keep up good work, Stefan
thanks guys here goes nothing lol
