Joined: 02/09/2012 Posts: 515 Points: 1,515 Location: Burnley
Hi Karl, Thanks, definetly taking my time and dry fitting several times before commiting to the PVA glue!! Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Waiting in the wings: Polarlights Spindrift from Land of the Giants.
finished: 007 Iconic DB5.
Hi Mike, Thanks for looking in and the words of support. I am actually enjoying this part of the model. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi Alan, Thanks. Great fun, but a long way to go. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi Dominic, Thanks. The flash I think was brought more of the pattern out than normally shows. I think the couch will be appearing in many more shots in the future, it is a nice soft resting place for the camera shoots Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi All, Just an update on the planking, slow progress, as trying not to rush. The pics speak for themselves. One or two areas not even, not sanding and filler should sort that out. I have lightly sanded a couple o spots and it seems to do the trick.      I will post more photos of my progess at the weekend. Thanks for looking. Claret. Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Taking shape very nicely there Claret... well done, keep the good work going and looking forward to seeing more.... Regards Alan
Hi claret. A very nice clean build. Look forward to seeing your progress. Keep up the good work. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
H Alan & Ian, For your kind words of encouragement. Not much progress, other commitments taking priority at present. Hopefully start #24 instructions this weekend. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi All, Been a busy two weeks, so not a great deal of progress. Managed to cut and sand the infils up to issue 23 Fiddly, with sanding a bit, not fitting, sand a bit more. results below:    Thats all for now. Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
That's looking good
Thanks andy. Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi, you are making good progress  Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Coming along very nicely Claret, well done.... Regards Alan
Joined: 24/09/2012 Posts: 491 Points: 1,452 Location: London
Looking good claret, almost there  If i might add because its hard to tell, but you might be needing to leave more bamboo planking at the end of the keel for the stern post, keep up the good work :) Processing - Progressing
Previous builds: HMS Victory Current build: HMS Sovereign of the seas
Hi Claret, The build is looking good WTG. Would like to pick up on the Admiral`s point in the previus post, about the length of the stern planks past the end of the keel. I have left mine a bit longer than yours ,but I can`t find any reference to there being any set length to leave past the end of the keel  . As a newbie to this maybe one of our more advanced members could clarify this point. Keep up the good work Claret. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
delboy271155 wrote:Hi Claret, The build is looking good WTG. Would like to pick up on the Admiral`s point in the previus post, about the length of the stern planks past the end of the keel. I have left mine a bit longer than yours ,but I can`t find any reference to there being any set length to leave past the end of the keel  . As a newbie to this maybe one of our more advanced members could clarify this point. Keep up the good work Claret. Regards delboy271155 (Derek) Hi Claret, I covered the overhanging stern planks issue with MWG in my build diary... If you take a look at post no 519 onwards I think you will find it very useful..... Keep up the good work... Regards Alan
Hi Alan, AAS & Derek, Thanks for your comments and pointing out the stern planking over hang. it does seem vague and i may have cut off more than i should have, over keen with the saw. Fingers crossed Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi, I have made a little more progress with fitting the stern reinforcement, I followed gandale's method of gluing and sanding the profile, fiinding this much easier.  Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi, Made some progess on the launch swell. I fitted 5 thwarts instead of 4 as I had an extra oar notch. Does not look to out of place, I hope I used a pair of compasses to get the correct length for each thwart. Result as shown in the photo.  That's all for now. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Nice work Claret and no the extra thwart doesn't look out of place.....  Also happy to hear my methods have helped you on the stern reinforcements..  .. Keep posting, your work is looking very good indeed.... Regards Alan
