5 Pages <1234>»
Routemaster bus build Options
#21 Posted : 16 March 2013 19:01:22
BigGrin hi try a ratio of half paint half water if this is too thin then add a little more paint, it depends on the paint your using some are thicker than others out of the tin so to speak. hope this help's
#22 Posted : 16 March 2013 19:38:05
Hmmm I have never used water to thin my paint and some acrylics react badly with it (MrColor turns to string in water), I always use the thinner for the paint i.e Tamiya or MrColor, it dries quicker and most is self leveling. And I thin mine 1 part paint 2 parts thinner, or on a non technical spec, the consistency of skimmed milk. I spray at 8 psi pressure at the gun, never had any problems at all. I spray at a distance of around 20 cm, light coats. Let each coat dry, and keep going until you get the finish you want. In between coats I check for dust specs and flat of with 1200 grade wet and dry if possible or a fine nail buffer for awkward spots. But its a case of experimenting. I have an old Sherman that I try new techniques on until I am happy so I don't ruin a proper build. Everyone on here has their own way of doing things, so my way is not everyone's way, its a case of play around with your paints and settings until you find a mix that works for you.
Hope this helps in some way.
NemBigGrin BigGrin BigGrin
#23 Posted : 16 March 2013 20:02:52
this is an interesting discussion as i have a a double action airbrush and a compressor you can not change the pressure on. i don't use it for two reasons - i found it takes 6 times longer to clean it than use it and i could never seem to get the paint to not clog i guess i thinned it wrong but i just used to get spatter. i would love to master an air brush would be handy for big hulls etc but also for weathering - i wonder if it was just the kit was rubbish? the brush is a paascha?
#24 Posted : 16 March 2013 20:22:23
Both mine are double action but you NEED a regulator on your set up. To be honest both my brushes are £12 each, its not the cost, but how you set them up and keeping them clean. And I do admit, cleaning is a pain in the ass!!
If its clogging it may be your paint is too thick or your pressure is too high causing the paint to dry in mid air or too low causing it to stick in the nozzle. I spray cars in my job, and setting up your pressure and gun is exactly the same principal.
NemBigGrin BigGrin
Trotsky
#25 Posted : 16 March 2013 20:27:06
Quote:
Don't know much about London Buses, but I did work for a week in the Jacobs Cream Cracker FactoryLOL LOL
When I first came to this country I worked for an agency and I had a job for a week in the Gordons Gin factory near Basildon, for 5 long days I emptied miniature bottles of Gin into a vat to be destroyed ...
The info on paints and airbrushing is very usefull more please...
H.M.S Victory
H.M.S Victory X Section
H.M.S Surprise under the bench
D-51
Trotsky
#26 Posted : 16 March 2013 20:28:25
opps missed the quote box ...anyhow it was Court-Orchard
H.M.S Victory
D-51
petpole
#27 Posted : 16 March 2013 21:48:14
Thanks all for the depth of knowledge about airbrushing I think that with the amount of different paints and wether it enamels or acrylics it is only trial and error and to how to get the best finish with them.
I have been practicing with mine on the inside box of the bus will some paint I will be using on the model just to give me the feel and the best combination of ratio's ( water- paint ), its not an exact science just what comes out best for the type of kit you would be using.
The only thing I can say is never give up on trying to use one, the results might just amaze you.
BigGrin BigGrin BigGrin BigGrin BigGrin
Thanks for look at my build be putting up some more pics later.
petpole
#28 Posted : 17 March 2013 13:49:04
Been doing the chassis on the bus this is the finished article.
All comments welcome.
Trotsky
#29 Posted : 17 March 2013 14:12:32
Great stuff I love this build
H.M.S Victory
D-51
RobT
#30 Posted : 17 March 2013 21:21:01
Looks good. I've got a brand new one of these in my wardrobe. Never got round to it as I couldn't get on with airbrushing.
petpole
#31 Posted : 19 March 2013 00:26:48
Just a couple of bits I have been doing so far.
These are just some of the seats that I have done.
This is a very detailed kit with nearly 400 parts involved.
Hope you like it so far all comments welcome.
DavidM
#32 Posted : 19 March 2013 09:23:13
Rank: Beginner Level 3
the wheels on the bus go round and round looking good keep it coming
Hans
#33 Posted : 19 March 2013 09:54:56
Brilliant stuff Peter. Well done.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
SennaMentalMe
#34 Posted : 19 March 2013 14:20:39
A great build so far Peter and an unusual subject - very nice indeed!! Cool ThumpUp
I like the look of this model and I believe that Revell also do a 'London Taxicab' model to compliment the bus? If the bus is anything to go by then the cab would make a nice model as well I think.
Great stuff keep up the good work and thanks for posting such an interesting build, watching with interest!!
Kev BigGrin
petpole
#35 Posted : 19 March 2013 14:29:47
Yes the model is the best I have build so far, it is so easy to put together following every step LOL .
The taxi will be next on the list if this build goes the way I want.
Thanks for all the comments.
#36 Posted : 19 March 2013 18:59:35
Looking good!! And really nice to see something different!! Well done and keep the posts coming!!BigGrin BigGrin BigGrin
#37 Posted : 19 March 2013 19:49:09
BigGrin Looking good thereCool
petpole
#38 Posted : 19 March 2013 21:18:29
Just thought I would put a picture of all the paints I use in the building of the bus.
The cost of the paints out way the cost of the bus but if a jobs worth doing push the boat outLOL .
Just hope the end result is worth it.
BigGrin
petpole
#39 Posted : 21 March 2013 17:02:27
Just a little more done on the bus.
This is the finished cab area.
And this is the engine now fitted with the cab and some of the seat.
Hope you like the build.
#40 Posted : 21 March 2013 17:10:53
Hi Peter, avery nice buildBigGrin Kind regards Mike
5 Pages <1234>»
This page was generated in 0.166 seconds.
