 Rank: Pro Groups: Registered
Joined: 25/03/2010 Posts: 100 Points: 289 Location: derby
Do you think we may be able to get any spare parts to replace any broken or accidentally damaged parts whilst attempting to glue or drill.
My number 12 broke but I stuck it together not to bad but I am having trouble drilling small holes in the brass strip for the cannonade. I really could do with another piece of metal.
i have a fear of losing a tiny bit.
thanks Shipmates for all your help Pam
Joined: 02/04/2010 Posts: 491 Points: 1,460 Location: Poole
In the absence of a replacement brass strip (I didn't use the ones that came with my carronades, so if you need one, simply PM me with your details), otherwise, you might consider fashioning a suitable part out of styrene strip or, given your experience with wood, maybe some off-cuts. As a last-ditch suggestion, (if you are feeling brave) you could even cut a metal bean/soup can up and use the metal from that. Schnellboots on back burner
Tools.
Thanks So I could cut some wood and paint it gold/brass brillant Pam
Joined: 13/10/2011 Posts: 851 Points: 2,628 Location: Leeds, Yorkshire
Hi Pam
You could also go to to Cornwall Model Boats and order some replacement brass strip. It isn't very expensive and it would give you some stock for future use in the project.
Mike T
Thanks will do that as I would like it to look good I need a dremel stand now looked at ebay -no good as I have problems looking though the magnifying lamp and getting the drill in ---all this keeps me out of mischief Pam xx
Joined: 20/04/2010 Posts: 545 Points: 1,536 Location: lossiemouth
brass strips if you go to in store or pound land and buy picture hanging kit the small,brass brackets may do, per drilled ,cut to size with the hole where you want it , holes 1.5 mm also nice brass coated nailes which i have used in sead of brass wire with the kit
Joined: 25/04/2010 Posts: 748 Points: 2,285 Location: bognor regis
hi pamlupo...i had the same problem i found a shop on the internet called macc models i bought a 300mm x 300mm x 0.3mm thick sheet of brass for only £5.50 plus £2.50 postage arrived in 3 days....i can make as many mistakes as i like now and it cuts with kitchen scissors cheers benny
 Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,827 Points: -13,348
As a printer or 25 years (litho) I used alluminium plates, these are think enougth to cut, shape et. f you haa lookthought yourlocal yellow pages for Litho printers and give them a call and ask for discarded plates, you may find them useful. these are exmples of what can be done, all metal litho plates.   worth a go eh!
Joined: 06/05/2010 Posts: 233 Points: 708 Location: Leigh on Sea
Colin...My wife is a printer offset Large Mann Machines I used to use plates from the old press she operated a Goss community,I got a bit concerned about chemicals on the plates I was wondering if these are the same as those you use or used,and should I not worry...printing daily redtops they use a large amount of plates and are readily available to me...sorry to go off topic folks H.M.S Victory H.M.S Victory X Section H.M.S Surprise under the bench D-51
Nah, they can be cleaned with white spirits and/or water, you would also be using the reverse side of the plate. For the ammount you would be using it would be negligable.
thin metal sheet,buy a tin of adsa coffie the seal on to is thin alluminium about 150mm in dia bit of sheet metal plenty of coffie
Joined: 26/03/2010 Posts: 600 Points: 1,959 Location: Solway West Cumbria
One hint pamlupo....is build up a bits box....bits or sheets of balsa and lite-ply..bits of tin or brass..pins..even bits of thread (various thickness).not huge amounts...from art shops and hobby shops...and check out e-bay (cool for bargains).....because something somewhere will go wrong..(as many of the well experienced wood ship builders have said)..and you have your box of bric-or-brack....to help sort it out....hope this helps ..John....
Thanks everyone I have looked at Cornwall boat site and there are various brass strips. I do not know which one to buy, I have rang them and left a message -no reply- I have emailed them -no reply. I want to replace the brass strip for the cannonade which is 2.6 mm wide. When I looked at the strips `I couldn't see the same size. Can anyone help me please which strip I need. Pam
Joined: 30/03/2010 Posts: 66 Points: 191 Location: Britannia
Get the 0.5 X3 X 500mm strip it is as close as you are going to get it is a fraction wider and thicker but you will not notice it.
Thank you so much it is appreciated and will order straight away. Happy building Pam
Sorry I can't find that size on the cornwall model boat site? Is it me ? Pam
Macmedal wrote:Get the 0.5 X3 X 500mm strip it is as close as you are going to get it is a fraction wider and thicker but you will not notice it. I agree with Macmedal in getting a thicker brass rod ....the wheels fit on more snug and stops them from bending in....but you will have to enlarge the holes in the carrage..(very carefully)i'm not sure what...0.5 x3 ...is ...i used 1.2 mm brass rod...2 pieces 300 mm long for 1.30 plus postage off e-bay
