Joined: 09/02/2012 Posts: 569 Points: 1,675 Location: Scotland
moriarty wrote:You are learning Mo, thats the exact same way as I have always done them. Practicaly foolproof as long as you dont overdo the tension. I am happy enough with them, but as I tension the shrouds I feel the thread on the bottom shroud is being pulled up, I am also trying to put a bit of tension on the shrouds to pull the mast over a bit,
MoMo
I am now tying the threads to the second section of the main mast, My mast is leaning over slightly, so I am rigging out one side with the hope of pulling the mast over, There is not a lot in it, I put a plumb line on the the main mast from top to bottom to check it trueness.  The only thing being the point at the top is virtually floating, But a plumb line is a plumb line, and its a good guide. I have also put a plumb line on the wall at the back of the ship, to line the mast through with the eye. I am going to finish one side, inc the ratlines, and this should help rectify the trueness of the mast, But as I say there was probabally only 10mm in it from top to bottom, I would only need to knock the hull 1mm of the level to make the masts plumb. Mo Mo
looks really good can't wait to se her rigged xxxx “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
As per usual Mo, some more very nice work there... Love this build...
Can't believe how long it's taken to tie all the ratlines to the main mast, anyway all three sections done, I made 2 half hitches to each knot, thats a total of 2304 half hitches, The model is so tall, I had to stand to get the second and third lifts done, I found that back breaking, Anyway all done now, next is to do the foremast, May be moving house shortly, that will put a hold on the ship for a while.
Mo 🏠 🚣 Mo
rigging looks perfect “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Cracking job there Mo.... looks superb... Regards Alan
Thanks for the support, Jase and Grandale. I'll keep tying these knots.
MoMo
 Rank: Pro  Groups: Registered
Joined: 17/03/2010 Posts: 301 Points: 941 Location: fife
great job on the rigging Mo, i know how you feel about time spent on this, i have just finished the lower section on the main mast on Victory, only 11 sections to go, boy does time slow down when doing this. Even with a Miniart diorama and 1/35 scale german halftarck as a distraction. current builds
Joined: 13/01/2012 Posts: 605 Points: 1,630 Location: Bucks
All good fun eh Mo HMS Surprise HMS Snake HMS Bounty HMS Royal Caroline HMS Victory rebuild HMS Supply
Good job there MO. She beginning to look real grand. Well done. To assist with the rigging on the Vic, I hijacked a small coffee table (shhhh swambo doesn't know yet)so I did not have to stand. Just a thought. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Joined: 20/10/2010 Posts: 511 Points: 1,459 Location: Loughborough
What a great build of the rigging you are doing, I can't wait to get to it on mine (not lol) all them knots will send me blind, showed one if my kids your build and told them that's what I have to do and the response I got was good luck  . Keep up the great build. Builds in progress: HMS Victory.HMS Surprise. Completed builds: Revell London Bus 1/24. Builds to do:Sovereign of the seas, Hms Albion.
Beautiful clean build, the rigging is impressively neat. The endless knots I remember well, I found trying to do at least a few every night helped and time as it does passes, every knot tied is one less to do.
Not a lot to report just now, doing the shrouds, deadeyes and ratlines to the upper sections of the foremast just now, after that I will do the work to the bow, to enable me to get the bowsprit fitted, will post some pictures of my progress shortly.
Mo. Mo
Well as I said earlier, be moving house soon, had to pack up all my kit. Hope to be back soon, but will look in every so often to how progress is going.
Mo  😂 🏠 🚚 Mo Mo
ggod luck with the move mo, don't forget to bag the workshop first, no use movin' unless you have a bigger workshop/shipyard. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Hope you have a great move Mo, come back building soon in your swanky new dockyard  . Builds in progress: HMS Victory.HMS Surprise. Completed builds: Revell London Bus 1/24. Builds to do:Sovereign of the seas, Hms Albion.
Joined: 25/01/2010 Posts: 459 Points: 1,367 Location: Bridlington
Hi Mo just had a look see what u mean about the pins lol, like the tape idea I will post pic's when I have done thanks mate.Regards
Rob
Bridlington.
Built Flying Scotsman (Train). Collecting HMS VICTORY
Hope the move goes well don't be away to long “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
