 Hi All First coat of dirty yellow on the upper hull, appologys as the paints still a little wet but it looked so good I couldn't wait to post regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 27/08/2012 Posts: 104 Points: 312 Location: Brome Lake Quebec
This is certainly growing into a big beauty Andy. Those little PE additions really make this a nice model. Bravo so far and looking forward to this progressing. JOhn
 Hi Yamaska and Nem Thanks for your comments, there's still quite a bit of etch to add but all worth it I think regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Gun carriage made up and the small amount of etch added and the 1st coat of yellow applied regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy, not really into military modelling myself, used to build gliders in my youth but that's about all, some of them actually flew, if only for a short while....  .... I do love following your builds however, they are very informative and the tips you provide are superb.... will keep watching to see how this one develops...... very well done..... Regards Alan
Joined: 13/01/2012 Posts: 605 Points: 1,630 Location: Bucks
Looking good, all that etch certainly gives it a better look HMS Surprise HMS Snake HMS Bounty HMS Royal Caroline HMS Victory rebuild HMS Supply
Your really getting on now Andy, looks superb! Tempted to dig mine out now!!!
Looks a nicely detailed kit and should produce a nice model
 Hi Alan, Moriarty, Nem And Tom thanks for looking in and your comments, the etch has certainly made a difference as you say regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All done a little more, the etch is taking longer than expected but I have made up one side of the floor plates, the hand rails still need to be fitted here but they will go on last. As always all comments/questions are welcome regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Superb work sir!!  Really coming on now!!
 Hi Nem thanks for looking in and your generous comments, the etch is taking a lot longer to do than I thought but the results speak for them selves I think regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 06/06/2010 Posts: 566 Points: 1,657 Location: UK
Looking great Andy, am following with keen interest.
Wilfy
 Hi Wilfy Thanks for looking in and your comments Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All I have now finished the floor plates apart from the railings [more etch to go on these too] . Also iv made up all the major components that were left such as the main mortar and shell load tray. The mortar had moulded in rifling but also supplied was a replacement etch item which has been fitted and the spring action recoil has also been fitted. There's now plenty of painting to do plus weathering to come and the crew to be made up, as always all comments /questions are welcome regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Nem She's certainly bigger than I thought made up, thanks for looking regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Some more progress on the hull , The majaratory of the etch has now been added to the hull and the final coat of dirty yellow added, also the loader ,gun , and gun carriage have had there coats of yellow and any etch added. The railings have had the etch brackets added and have been painted ready for fitting. The eghaust pipes will be fitted last after the camo has been sprayed. As always all comments/questions are welcome regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
