17 Pages «<23456>»
Jase's 1/200 Trumpeter Bismarck with upgrades build diary. Options
#61 Posted : 11 March 2013 20:21:39
court orchard wrote:
On a more positive note, I can recommend the Kagero 3D book on the Bismark which has excellent detailed drawings, particularly of the Superstructure.
http://www.amazon.co.uk/Bismarc...id=1362912377&sr=1-4
Looks a good book. I am probably not going to purchase any books at this stage, i have a few bismarck books that tend to be around the story rather then the design of the ship. I think there is enough primary resource on the net to get the job done.
That's probably right, I'm still a bit old school and can't get the same enjoyment from the Net as Ink and Paper. I tried a Kindle last year but it didn't hit the spot. I'm a Dinosaur on the Eve of ChicxulubLOLBored
Well the pen is still mightier than the sword BigGrin Ill be posting all my reference links as i go.
court orchard
#62 Posted : 13 March 2013 10:38:03
Someone on another Forum has spotted an error in the KA MK1 instruction sheets, thought it would be useful to flag it up here.
Post #5 on this page.
http://www.shipmodels.info/mws_...mp;t=149456&start=40
#63 Posted : 13 March 2013 12:20:45
Thanks for the link BigGrin
#64 Posted : 13 March 2013 23:12:04
Prepping the Hull Continued.
Total build hours 7.5
I have fixed all the lower hull items on with the exception of the propellas i am hopfull of adding some brass ones but been unable to source any so far. I have filled all the gaps and started the proces of sanding wich will remove the eyebrows and hand irons that i will be replacing with etch.
The little rectangilar strips on the rudders are zinc strips, there should also be three on the propeller shaft support (see link for wreck reference pic)
http://www.bismarck-clas...k/bismarck_wreck_5.html
I have added these scratch built from plastic card they are 3mm x 1mm.
#65 Posted : 13 March 2013 23:16:00
Excellent build diary, very interesting and factual too. What were the zinc strips purpose where they are placed? BigGrin BigGrin
#66 Posted : 13 March 2013 23:28:11
BigGrin nice work JaseCool
#67 Posted : 13 March 2013 23:40:57
I understand the zinc strips where supposed to keep various waterborne nasties from attacking the vital parts - not sure of the since behind it.
court orchard
#68 Posted : 13 March 2013 23:41:38
I've seen these on another build, but only 2, been trying to find out what they were. Are they sacrificial anodes, to avoid screw corrosion? My other question is are they on both arms of the support or only the outer arm?
#69 Posted : 13 March 2013 23:54:28
I think they are just on the outer leg that is what I will be doing. Defiantly three not two as the if you follow the link and scroll to the bottom you will see a pic of the wreck with the three visible. Also these are not hull red they are white. Interestingly the Tirpitz had a slightly different arrangement
Hans
#70 Posted : 14 March 2013 08:56:42
Looking good there Jase. Very interesting and enjoy your attention to detail.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
court orchard
#71 Posted : 14 March 2013 10:27:30
Sorry Jase, I read through too fast and missed the linkBlushing.
You are quite correct there are 3.
They are Sacrificial Anodes (or Galvanic Anodes) these are used when Metals are in corrosive environments, that is buried or in this case in Sea Water. The process is to use a metal which corrodes more readily than the Metal you want to protect (because of it's higher Electrochemical Potential) usually Magnesium, Aluminium or Zinc (Zinc was a preferred option in Sea Water). What happens, is that these blocks corrode first rather than the valuable parts, in this case I think it's the Propellers/Screws, which are of course bare metal. These Blocks would have needed replacing regularly, as they 'took the hit' and 'rotted' away. I'm surprised that anything is left as the corrosion would have continued at the bottom of the Ocean. Maybe it's just a mounting left? Although I suppose the Props would've no longer been moving and therefore continually scoured, so would've formed a protective oxide. As to colour they would have been Bare Zinc Metal, as Paint would defeat their purpose.
#72 Posted : 14 March 2013 11:53:16
[/quote]
Thanks Andy, so colour would be silver grey?
court orchard
#73 Posted : 14 March 2013 13:06:04
I guess a Dullish Silver Grey would be about right, the same colour as Galvanized Steel which is a Zinc Coating.
#74 Posted : 14 March 2013 16:34:54
Prepping the Hull Continued...
Total build time 10.5 hours
I have now completed the initial sanding of the hull. The sink points have sanded out ok I only really needed to fill at the bow. All the hand irons and eybrows have gone, I also removed the little molded on brackets as i will be replacing these.
Next job was to fit the deck to allow me to make a couple of further modifications to the hull. The deck goes in snugly with only some very minor gaps to fill.
As always any comments warmly received Thanks
court orchard
#75 Posted : 14 March 2013 19:25:18
Hi Jase,
I've just noticed that there are Sacrificial Anodes on the Rudders as well 10 on each side of each Rudder. Trumpeter have thankfully added them. So these will need painting Zinc too.
#76 Posted : 14 March 2013 20:37:21
Hi Jase,
Yes if you look at my pis above you will see that kit provides the rudders with them already on and in the correct positions.Cool
#77 Posted : 14 March 2013 21:16:49
BigGrin Hi Jase
It would seam we both got the good hulls as there have been a few issue's with the hulls being out of shape on other forums also my decals have the arms of the swastika but not the central cross, its not really an issue though as I will be building mine in atlantic break out paintwork so they were painted out anyway. Keep up the good work
#78 Posted : 14 March 2013 21:42:32
Hi Andy,
i was not aware of the hull issue, glad i did not get one Mellow yep the decals don't have the centre cross because it is illegal to display or trade items with swastikas in Germany. To be honest i would have preferred a stencil to a decal I have not decided what i am doing with the deck markings yet. All sorts of theories fly about the net but the wreck clearly shows grey paint still over the markings in patches - and i still fancy yellow turrets Flapper
#79 Posted : 14 March 2013 23:13:14
Coming together very nicely Jase.... following with interest even though I don't think I would be building these kind of ships... sailing ships is my preference.... at least for now that is..Cool Cool
#80 Posted : 14 March 2013 23:16:08
Well Alan if you were to ever do just one war ship this would be the one even straight from the box its a tremendous kit.
17 Pages «<23456>»
This page was generated in 0.267 seconds.
