3 Pages <123>
A new start by Delboy Options
#21 Posted : 10 March 2013 13:37:19
Hi AllBigGrin
Time for a bit of an update!
Firstly for those eagle eyed amongst you, after a little battle to seperate the parts I have reassembled the ships anchor stock in the correct orientation.Pic 1
Having that back on track I continued with the bow formers, which will be balsa infilled in the near future. I will be doing the infills before I fit the bow to the false keel,as I found it awkward
on the Soveriegn to work with the whole hull, that and the fact that the bow end of the false keel has been in need of a soak and flat clamping session,(nearly there now).
So bow formers,Pic 2+3
Time for that to fully set before the infills.
Next I decided to make a start on the carronade. Well, that`s where the discussions started as to the correct position of the wheels.Having looked at several photo`s
and a great drawing supplied in the discussion I decided to position the wheels slightly in from the back edge of the base, with the rear eyelets behind the wheels, not in front.
That decision made, I started to assemble the base, only to find another problem. With the rear wheel assembly made, I had a dry fit of the base and soon realised
that the front mounting block needed to be twice the thickness supplied or the whole issue sloped down towards
the front.
This is the state of play at the moment.Pic 4
While that was in the process of drying, I turned my attention to the ship`s boat, being careful to get the frames square and I have this morning started to plank.Pic 5+6
Well that`s all for now,as usual comments and critics welcomeBigGrin
#22 Posted : 10 March 2013 13:43:47
hi del,if you would like to look at my link which is on my list of boats,you will see "upgraded launch" it may help you in your build.most of my builds you will find there under my ugly mug,also the sergal victory launch is worth looking at.
#23 Posted : 10 March 2013 14:02:54
Thanks Karl,
That looks the real business and has opened up the thought processes.
#24 Posted : 10 March 2013 16:20:07
Hi Derek.
Looking good. Keep the pictures coming. Ian.Cool
#25 Posted : 10 March 2013 17:30:29
ian smith wrote:
Hi Derek.
Ian,
Many thanks for looking in. Choices at the moment are Plank the SOTS or Plank the Vic`s boat.
Looks like planking Crying is the order of the day LOL LOL LOL LOL .
#26 Posted : 10 March 2013 21:25:00
Nice work Derek, doing the launce, the vic and the SOTS all at the same time looks as if you could be planking till xmas..LOL LOL ... good luck and well done..
#27 Posted : 10 March 2013 21:35:39
Thanks Alan
Think I will be seeing planks in my sleep soon LOL LOL LOL,talking of which 3am start tomrrow so better be off to bed.
Happy Modelling,
#28 Posted : 14 March 2013 15:08:15
Hi All,
Mini update, as back giving me grief and pain so can`t sit for too long in one position.
Following up on the bow formers, I have done the balsa infills and got it back to the basic shape prior to fairing at a much later date.Pic 1
After a two day pressing session on the bow section of the false keel, which has been a success, I checked on the ribs and as they were ok had a fitting session. I put these under a bit of pressure overnight while they set.Pic 2
I won`t be assembling the false keel/ribs for a while yet, I`m going to wait until I have all the keel parts and ribs and then have a serious building session.
In the meantime I will be stripping down my Sots dry dock as it`s no longer needed and prepping it ready for the Victory.
Next on the shopping list is some bigger and better brackets than those used on Sots, then when I`ve got all the keel parts it will be down to rebuilding the dry dock.
#29 Posted : 14 March 2013 15:57:29
hi del a little tip here mate,the joins of the ribs to the "b" sections,needs to re-inforced with a bit of planking,as the charred edges WILL NOT bond,test them out and see.also by adding the bits of plank,it stiffens them up against accidental breakage.
#30 Posted : 14 March 2013 17:37:05
Hi KarlBigGrin ,
Thanks for the tip, I have very lightly cleaned the charred edges with a micro file and will be doing a full balsa infill build as I did with the Sots, so will the reinforcement still be needed?
#31 Posted : 14 March 2013 19:47:58
I would del,as the balsa does not go all the way up,and the skinny bits are exposed.I would just do the skinny bits, not the joint.
#32 Posted : 14 March 2013 20:21:04
Cheers Karl
That makes sense, as I have recently had a breakage(which fixed ok) on my Sots build, may have to be a bit careful though cos gun ports sometimes get very close to the ribs.
#33 Posted : 26 April 2013 20:27:56
Hi All,BigGrin
As this is my number 2 build, just a small update while planking on the SOTS dries out.
I have finished the planking on the Victory launch, which if I say so myself is better than my first attempt on the SOTS. As they say practice makes perfect, well maybe better LOL LOL LOL .
The pics are below, you judge Flapper .
No, seriously though any advice good or bad will be gratefully appreciated.
#34 Posted : 26 April 2013 23:00:46
hi del, acouple of tips here might help, the planks I found a little wide,so I cut mine down with a pair of scissors down the middle, and then tapered them BOTH ends so I didn't need to use sharp points on any of the planks. then after sanding down I put an other layer of planks on in a different wood mahogany or walnut 3mm.x.06mm leaves a nice finish. K.
#35 Posted : 27 April 2013 09:43:07
Hi Derek, nicely done.... think your build is coming on a treat.... BigGrin BigGrin .. Once you sand the launch down it will look the part ready for painting, just be careful not to sand too much off as those planks a really thin.... I take it you are going to paint or do you intend to go for the natural finish?? BigGrin BigGrin
#36 Posted : 27 April 2013 19:22:58
Hi Karl/Alan,BigGrin
Thanks for the tips and comments chaps and Yes I am going for the painted versionBigGrin .
#37 Posted : 18 August 2013 10:20:19
Hi All,BigGrin BigGrin
Had enough of planking the SoTS, so it`s back to the Vic for a while.
Now, it`s been said on here before that there are "no problems, only solutions".
So to that end I`ll start with the problem.
Bow Keel Section
Serious twisting and warping of the part was the issue. I have been down the route of soaking/steaming then clamping/pressing but it just came back to the same awful shape.
That left me with two possible solutions:
1: Order new part from Deag - Can take to long
2: Make a replacement part - If this had failed I`d be back to #1.
The extent of the twist.Pic 1
The craft knife shows how far out of straight this part was.
Making the replacement
Some while back I bought some plywood off cuts at the Coalville Boat Show, you know the "some day this might be useful"
well the day had arrived.
First I marked round the old piece with it firmly clamped in place.Pic 2
I then cut out the edge where it joined the centre keel section (most difficult edge first)Pic 3
From there I rough shaped the keel shape and cut the top edges.Pic 4
The keel front edge was then shaped with the old and new pieces clamped together.Pic 5
After that the wider slots were cut out using my Dremel and a reamer bit, then finished with a mini file.Pic 6
Using the same tools with a finer reamer bit I then cut the thinner slots.Pic 7
Now it`s new part in and old part out.Pic 8
EUREKA !!!!
Next update soon - Keel/Ribs and first deck assembly BigGrin BigGrin
NMBROOK
#38 Posted : 18 August 2013 10:32:35
Excellent work Derek!Cool Cool Cool
Kind Regards Nigel
#39 Posted : 18 August 2013 10:34:05
Nicely doneCool
#40 Posted : 18 August 2013 11:22:17
Superb Derek, job very well done.... Cool Cool
3 Pages <123>
This page was generated in 0.427 seconds.
