Hi Jase, The Porthole Eyebrows are included in the MK1 Etch along with all the Portholes, along with all the minute Grab Handles.
court orchard wrote:Hi Jase, The Porthole Eyebrows are included in the MK1 Etch along with all the Portholes, along with all the minute Grab Handles. Thanks for the info that's great news. Have you started yours yet wold love to see you progress “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Very nice start Jase.... will be watching to see how you progress with your modifications.... been some 45 years since i built a war ship, airfix bismark, pretty basic and cheap... saved my paper round money for that one..  ... From there I moved onto gliders and was chuffed when they actually flew... stopped modeling altogether when I reached 16... Think I have missed out on so much of this hobby through the years but at least back on it now and loving it..... Regards Alan
jase wrote:court orchard wrote:Hi Jase, The Porthole Eyebrows are included in the MK1 Etch along with all the Portholes, along with all the minute Grab Handles. Thanks for the info that's great news. Have you started yours yet wold love to see you progress Hi Jase, I've done some work on the Hull and added the main pieces, but that's it. The Hull is very thick and can take a lot of sanding, The Bow nose pieces didn't fit that well and needed quite a bit of work. I've been considering the PE for the vents, but I think that the moulding is OK and they will look too obvious with PE. I'm a bit fazed by all the tiny MK1 PE and the Hull painting (ie Boot Top) so I'm kinda waiting for you to lead the way
court orchard wrote:jase wrote:court orchard wrote:Hi Jase, The Porthole Eyebrows are included in the MK1 Etch along with all the Portholes, along with all the minute Grab Handles. Thanks for the info that's great news. Have you started yours yet wold love to see you progress Hi Jase, I've done some work on the Hull and added the main pieces, but that's it. The Hull is very thick and can take a lot of sanding, The Bow nose pieces didn't fit that well and needed quite a bit of work. I've been considering the PE for the vents, but I think that the moulding is OK and they will look too obvious with PE. I'm a bit fazed by all the tiny MK1 PE and the Hull painting (ie Boot Top) so I'm kinda waiting for you to lead the way I agree the hull vents are fine, I will try and do my best to explain all the techniques i use as i go along but you can always ask anything as we go. Boot top will be a challenge as it is not marked. i have a 1:350 tamiya kit though so plant to take measurements and scale up. I think after the hull should be relatively straight forward construction - famous last words. Are you going to put a build diary up? it would be good if we could get 2 or three going. Going to model boat show Sunday see if i can get a nice stand “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Thanks Jase  I might do a Build Diary, but I'm a bit of a novice when it comes to plastic Battleships. I notice that there's a problem with the Boot Topping/Waterline level at the Stern. If you mark it at a constant level from the Base it looks too low and needs correcting upwards. I saw that you were asking about Smoke Generator Canister Hatches on the MK1 Decking, they are there as you can see on the Photo, but no Crew Access Hatch to the Smoke Room as on the Artwox Deck.
[quote=court orchard]Thanks Jase  I might do a Build Diary, but I'm a bit of a novice when it comes to plastic Battleships. I notice that there's a problem with the Boot Topping/Waterline level at the Stern. If you mark it at a constant level from the Base it looks too low and needs correcting upwards. Thanks for the deck pic Andy Deck looks ok, I will wait and see for my self befor i decide if I am shelling out for another deck. I would not worry just go for it on the build diary front you will probably inspire more people to have ago and get more help ant tips from the forum that way. Interesting comment on the boot topping. The shape of the bow dictates that the line plunges under the bow also the depth of the line increses. I will post a pic of my 1/350 bis tonight to give you some guidance. J “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Joined: 06/06/2010 Posts: 566 Points: 1,657 Location: UK
Hi Jase, I am going to try & start my Bismarck in the next couple of weeks, looking at your posts so far, you are much more knowledgeable than I am about battleships. I don't understand the 'boot topping question' could you explain it in 'idiots' terms please. Thanks Wilfy
 I think this is right but not completely sure, The boot topping is a measure of draft that indicates to the crew its weight or where the red anti fowling paint meets the grey paint of the upper hull. So if a ship is riding high or light the red paint line can be seen, the more weight on the ship then it becomes lower in the water so a ship that is riding exactly to the boot topping line is at its optimum weight with a full crew and stores on board. Different ships have this line set at the design stage, thus a container ships can have a higher boot topping compared to a warship regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote: I think this is right but not completely sure, The boot topping is a measure of draft that indicates to the crew its weight or where the red anti fowling paint meets the grey paint of the upper hull. So if a ship is riding high or light the red paint line can be seen, the more weight on the ship then it becomes lower in the water so a ship that is riding exactly to the boot topping line is at its optimum weight with a full crew and stores on board. Different ships have this line set at the design stage, thus a container ships can have a higher boot topping compared to a warship regards Andy Thats pretty much it. all you need to know from a model point of view is that we are talking about the black line that divides the grey and antifouling red of the lower hull and runs the full length of the hull. On Bismarck the Boot Top was 2 meter deep on her sister ship Tirpitz it was slightly deeper.“Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Wilfy the Sea Dog wrote:Hi Jase, I am going to try & start my Bismarck in the next couple of weeks, looking at your posts so far, you are much more knowledgeable than I am about battleships. I don't understand the 'boot topping question' could you explain it in 'idiots' terms please. Thanks Wilfy Great Wilfy i am probably a couple of weeks from getting properly stuck in also - I just need to get Hood of my desk  and finally receive my upgrade kit. Looks like we could have 3 Bismarck Builds  which will be fantastic as they will all come out different I am going to do my Bismarck with yellow turret tops, just to be controversial J “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Thanks for info, think I understand the principle.
So the 'boot topping line' is the demarcation line between the red paint & the grey paint on the model. This is 47.5mm from the keel at centre, 42.5 mm at the bow & 44.5mm at the stern. So if I was to draw a line mating up these points I would have have the position to mask & paint the lower hull?
Thanks
Wilfy
Wilfy the Sea Dog wrote:Thanks for info, think I understand the principle.
Thanks
Wilfy Yes that would give you the top line the bottom line should 10mm bellow. Don't fall into the trap that some Bismarck model builders do and paint the false bow and stern black it should be very dark grey J “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Great Wilfy i am probably a couple of weeks from getting properly stuck in also - I just need to get Hood of my desk  and finally receive my upgrade kit. Looks like we could have 3 Bismarck Builds  which will be fantastic as they will all come out different I am going to do my Bismarck with yellow turret tops, just to be controversial J[/quote] I was going to start an aircraft kit next, but think it would be great if the three of use could work through the Bismarck together, I will have to take advice from yourself & Court Orchard as my knowledge of her is not great. Need to purchase some referance material I think. I have all the components here now, I bought the Lifecolour paint sets as I prefer acrylics, so I have no excuse apart from space to get going. Wilfy
I was going to start an aircraft kit next, but think it would be great if the three of use could work through the Bismarck together, I will have to take advice from yourself & Court Orchard as my knowledge of her is not great. Need to purchase some referance material I think. I have all the components here now, I bought the Lifecolour paint sets as I prefer acrylics, so I have no excuse apart from space to get going. Wilfy[/quote] There is quite a lot, and growing, reference material in the links on the first post of this build diary. i will be adding pic references as i go. try this for some stunning build reference material http://3dhistory.de/wordpress/?page_id=179
I agree three builds progressing together will be great, and hopefully we will all come out of this with something special. J “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Thanks for the link jase, will be very useful.
I just did a search on the 'anotomy of a ship' series of books looking for Bismarck & sellers on Amazon wanted £500! What!
Wilfy
Wilfy the Sea Dog wrote:Great Wilfy i am probably a couple of weeks from getting properly stuck in also - I just need to get Hood of my desk  and finally receive my upgrade kit. Looks like we could have 3 Bismarck Builds  which will be fantastic as they will all come out different I am going to do my Bismarck with yellow turret tops, just to be controversial J I was going to start an aircraft kit next, but think it would be great if the three of use could work through the Bismarck together, I will have to take advice from yourself & Court Orchard as my knowledge of her is not great. Need to purchase some referance material I think. I have all the components here now, I bought the Lifecolour paint sets as I prefer acrylics, so I have no excuse apart from space to get going. Wilfy[/quote] Talking of space, its looking like Trumpeter are lining up the release of a 1/200 USS Hornet aircraft carrier, which will be a serious space eater.. https://www.facebook.com...mp;type=1&permPage=1
Talking of space, its looking like Trumpeter are lining up the release of a 1/200 USS Hornet aircraft carrier, which will be a serious space eater.. https://www.facebook.com...p;type=1&permPage=1[/quote] wow that will be some serous kit “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Wilfy the Sea Dog wrote:Thanks for the link jase, will be very useful.
Wilfy flipin eck - is embossed gold leaf!!! “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
