7 Pages <12345>»
Dragon Morser 'Loki' Gerat build Options
#41 Posted : 28 February 2013 21:11:37
BigGrin Hi All
The hull base section is now compleat except for some dirtying up, I repainted the main rollers with Tamiya XF-56 Metalic Grey as any paint would soon disappear after a couple of miles running the upper rollers did have a coating of rubber so these were left matt black. The tracks also have had a coating of the metallic grey paint, I think this colour matches cast steel/iron quite well but im sure everyone has there own preferances here.
Andy Cool
#42 Posted : 28 February 2013 21:15:52
Excellent work Andy, I like it!BigGrin I use metallic grey on all my tracks as a base coat. I think gun metal is way to dark and I have not found another base colour I like. Looking forward to your next post and pics!!BigGrin BigGrin
Wilfy the Sea Dog
#43 Posted : 28 February 2013 22:58:00
Looking good Andy.
I always have a self debate about track colours, so many model paint call outs tell you to paint them rust, which is really not right unless it's an abandoned tank & not moved for a while.
I've now started painting them dark iron with a thin top coat of what ever environment I see them to be in, i.e. dark mud, light mud, sand, dry etc.
Think it will always be one of those contentious points.
Look forward to seeing your progress. (which I could progress as fast as some on here! BigGrin )
Wilfy
#44 Posted : 28 February 2013 23:36:53
BigGrin Hi Nem, Wilfy
Your right I think every one has there own method for tracks but I cant see a full coat of rust would look right or even be close to full size as any movement and the tracks rubbing as it travels overland would certainly take a lot of rust and any paint off them and keep the metal looking like its been freshly filed but I think there would be a small amount here and there where no contact is made. thanks for looking in and your comments more to follow soon
yamaska
#45 Posted : 28 February 2013 23:41:05
very nice progress. The base coat for tracks is less important in my view, than the weathering that follows. As it happens I tend to use a fairly light brown to start then some dark washes, some lighter dust/mud etc and finally a metallic dry brush. But as I say each to his own. I<ve just started to use Friuls so for these a light sanding will replace the final metallic dry brush.
Watching this one with interest.
John
#46 Posted : 02 March 2013 12:49:10
BigGrin Hi Yamaska
As always very sound advice
#47 Posted : 02 March 2013 12:50:11
BigGrin Under floor plates made upCool
#48 Posted : 02 March 2013 12:54:10
Ooooooo lots of shiny bits!!BigGrin Cracking build so far sir!!BigGrin
S2ksean
#49 Posted : 02 March 2013 13:18:14
Loving the build mate keep the pix coming
Sean
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#50 Posted : 02 March 2013 19:45:09
BigGrin Hi Nem , Sean
#51 Posted : 02 March 2013 19:46:14
BigGrin A little more progress on the mounting of the etch detailCool
#52 Posted : 02 March 2013 19:52:27
Superb detailing. The pe is certainly making a big difference. Nice work indeed Andy!BigGrin BigGrin
#53 Posted : 02 March 2013 20:59:46
BigGrin Hi Nem
As you say the etch is improving the look no end
Wilfy the Sea Dog
#54 Posted : 02 March 2013 22:37:02
Looking good Andy & as already said the pe is making the detail look fantastic.
Do you Super Glue all your pe?
Wilfy
#55 Posted : 03 March 2013 01:21:38
BigGrin Hi Wilfy
Thanks for looking in and your comments there always appreciated.
Most of the time I use superglue but on boxes I just assemble them and they generally don't need any glue if made up correctly, as for the miniscule bits iv used paint, white wood glue anything but super glue as I always get an overflow that masks the part even if I use a pin to apply the glue [ think iv got fat finger syndromeLOL ]
#56 Posted : 03 March 2013 18:21:24
BigGrin Hi All
A little more progress on the etch chains added and other various bits like the fire appliances [well I think that's what they are] and brackets then I added the driving compartment detail, the dashboard dials haven't been added yet as I have some dial prints on plastic to add here. Its suprising how time fly's when your adding etch, as usual all comment/questions are welcome
#57 Posted : 03 March 2013 18:32:05
Superb work Andy!!BigGrin Very impressed!!!BigGrin
#58 Posted : 03 March 2013 18:48:55
BigGrin Hi Nem
Thank you for your kind wordsBlushing
\ AndyCool
#59 Posted : 03 March 2013 19:43:09
That's what Iike to see lots of etch!!! It's looking great mateCool
#60 Posted : 03 March 2013 22:39:20
BigGrin Hi Jase
Thanks for your comments and looking in, the etch is taking longer than I anticipated but im enjoying it as its making a big difference in my humble opinion and still quite a bit to add.
7 Pages <12345>»
This page was generated in 0.225 seconds.
