11 Pages «<23456>»
Karl's Victory(Jotika Caldercraft) Options
#61 Posted : 22 February 2013 14:17:53
upper deck planked,side bulwarks installed,mast rings and bulwarks to plank next.
build log time total 160 hours.
#62 Posted : 24 February 2013 12:05:23
the bullwarls are now planked and mast rings installed.
build time log.170 hours.
#63 Posted : 26 February 2013 11:36:07
moving on to the the paintwork,yes this the order that caldercraft want you to do it,to get the stripes on before the bits and bobs go on,then the plating.I have only put one coat on with a brush,so if I knock it about,I can add other coats.
build log time now 190 hours.
#64 Posted : 26 February 2013 12:02:53
Hi Karl,
Looking very good, I think painting the hull at this stage makes a lot of sense where you have nice clean lines to mask off, then paint the other details before they go on. Im going to do the same to mine as soon as ive cut the quarter deck gun ports.
I think someone once built one of these jotika vics in 1000 hours, you're not going for the record are you ?BigGrin
#65 Posted : 26 February 2013 13:19:09
hi steve,no intention of going for the record,already had two setbacks,so slowly onward.and thanks for the comments.
Hans
#66 Posted : 27 February 2013 11:29:30
Good going there Karl. She looks great. The tiles should eat up the hours?
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
#67 Posted : 27 February 2013 13:44:37
yes hans,it sure will,having a break from tiles,I've started the exitway stairs,these had to be fitted with stanchions,so it's now my chance to try e-bays" BLACK IT". it really does do what it says on the tin,the etch stanchions were black in about 3 minutes straight out the packet.so I installed grates,stairs, black thread for the hand rails.really impressed with the black it, recommend it for blackening brass and metal work.
total build hours:- 200 hrs.
#68 Posted : 27 February 2013 14:18:44
Hi Karl.
Looking superb. Keep up the good work.
Thanks for the info on the pins.
Ian Cool
#69 Posted : 27 February 2013 15:38:48
thanks ian,your welcome over the clamps.
#70 Posted : 27 February 2013 16:20:44
Nice work Karl,you are moving with this build,copper tilies will slow you down a bit,well they did me,love the paint work.
Trev.
#71 Posted : 27 February 2013 16:31:58
thanks trev,only a quick coat,put the top coat on when the plating is done.
#72 Posted : 27 February 2013 21:46:22
Impressive looking Karl.... Well done and nice to see its to your usual very high standards.....BigGrin BigGrin ... Looking forward to seeing this build progress...
#73 Posted : 27 February 2013 21:53:48
cheers alan,nice to hear from you. k.
#74 Posted : 27 February 2013 21:58:06
Always looking in Karl and lurking in the background....LOL LOL
#75 Posted : 01 March 2013 11:27:15
Hi Karl
Looking like a very nice build you have going there. And what a great idea to paint the stripes before adding all of the other fittings.
Could I ask please as you are using that Blacken-it product does it rub off easily? I have been using Carrs Metal Black for Brass which works great but has the tendancy to leave like a surface soot which comes off on your fingers - not sure if this applies to all of these sorts of product?
Looking forward to watching how your build progresses.
Kind regards
#76 Posted : 01 March 2013 13:10:46
hi alan,thanks for the nice comments,the blacken it solution I have only used on the etch parts,their does appear to be a rough surface after using black it,but not noticed any residue,not tried it yet on the larger brass parts,will let you know on that one. k.
willz
#77 Posted : 01 March 2013 15:45:29
wow Karl looking good, that shipyard of yours is getting bigger !!
what happened to SOB`s build diary
#78 Posted : 01 March 2013 15:50:06
hi willz,sob has left,and took his diary with him,no idea why?
yep shipyard is a bit crowded,but getting bye,just about.thanks for the comments. k.
#79 Posted : 01 March 2013 22:35:10
Hi Karl, if your shipyard gets any bigger you may have to think of employing a pilot and harbour master....LOL LOL .. Think you need a display room for that little lot.....
#80 Posted : 02 March 2013 10:43:28
more shot garlands installed,more tiles laid(groan)
build log 216 hours.
Guest (6)
11 Pages «<23456>»
