1st plank and rib 20 Options
#1 Posted : 24 February 2013 12:18:01
Crying Hi all,
Planking WAS going fine, stern done, all bar the thin infills top and bottom. Even the first bow planks are sitting fine (was dreading that bit, first timer)but the first plank that crosses rib 20 will bend inwards slightly causing a dip in the hull top edge. As you go further down the rib it seems to sort itself out.
I can`t work out whyConfused , has anyone else had same problem and if so is it just a case of a very thin piece of packing?
Thanks in advance.
Delboy271155
#2 Posted : 24 February 2013 12:23:51
a general rule del,whilst planking you pack out any discrepancies as you go.is the other side bulging?? if so,you have a rib mis-aligned,if not,just pack out the offending rib.good luck.
#3 Posted : 24 February 2013 12:31:15
Karl BigGrin Thanks for the prompt reply.
Have just checked again and this time checked both sides, in a way thankfully it`s not a misaligned rib cos it`s the same both sides. So will set about the task of packing it out a bit.
Thanks again for your help.
Delboy271155
#4 Posted : 24 February 2013 12:36:31
del,can you check that the ribs were put in the right order,sounds silly,but I have done the myself,luckily I could put it right before the glue set.
#5 Posted : 24 February 2013 12:43:23
Hi Karl,
Checking that is a bit difficult, balsa infilled etc,etc, but it is only the very top of the rib that`s wrong rest of it is fine.
Thanks again,
#6 Posted : 24 February 2013 13:09:48
UPDATE
I have just been looking at this issue a bit deeper and closer.
I dry nailed some planks across rib twenty and it is only the top plank that is an issue, then on closer inspection of rib twenty it appears that there is a very small flat spot in the curve of the rib.
SandyM
#7 Posted : 25 February 2013 00:26:57
I had the same on that rib but only on the starboard side. Depending on how deep the depression is you can pack out or if its not to deep skim with plastic wood to get a nice flow before the outer planking is laid.
Sandy
Various balsa aircraft both rubber powered and RC
Billing Jyland
Billing Wasa
Billing Dutch Royal Barge (gold medal winner Germany 1975)
Scratch built HMS Victory using HMSO plans hull size 26"
Scratch built Yamato Hull size 8'8"
De Pardo HMS Bounty
Current build Sovereign of the Seas
#8 Posted : 25 February 2013 10:36:17
Sandy
Hi Sandy,
It took some of the scrap from the ship`s boat planking to cure but now look`s good. the next plank down should be ok.
Thanks for looking in.
#9 Posted : 25 February 2013 17:16:07
delboy271155 wrote:
Sandy
Hi Sandy,
Derek,
Had exactly the same issue with mine. It was only visable when looking along the line of the ship (bow to stern) and only on one side.
Required next to nothing in the way of packing oddly but really did stand out.
Kind regards
#10 Posted : 25 February 2013 17:38:43
Hi tony,
Yep my packing was very small, might even have a very,very small rise now compared to the second row of planks but nothing a fine sanding won`t cure. I am working on the basis that it`s easier to sand of a bit than fill, sand fill and sand again.
delboy27155
This page was generated in 0.139 seconds.
