Catheads Options
PLUTO
#1 Posted : 12 February 2013 11:33:20
HELP: I have just received the Flags and the 'Victory' name transfer. Am I the only one who thinks this is very oversized?. For the model it should only measure 60mm across not 78mm as supplied. I can understand size restrictions when it applies to small items, but there should have been no reason to print the name so large. As it is it will span 5 of the rear windows and not just over 3 as it should. Is it possible to acquire the name anywhere else? John
#2 Posted : 12 February 2013 11:55:02
Catheads?
#3 Posted : 12 February 2013 12:45:54
LOL LOL LOL LOL LOL catheads???????Confused Confused Confused
#4 Posted : 12 February 2013 13:01:23
Hi Pluto.
If you have a PC and scanner you could always scan the oversized items, resize them on any graphics program and then print them onto waterslide transfer paper to make your own. That's how I made mine up (except I had to design it from scratch). You can also use exactly the same procedure with T-shirt iron on transfer paper to make your own flags too! Both types of paper are available through ebay.
Best of luck
Robin
PLUTO
#5 Posted : 13 February 2013 12:42:49
Tomick wrote:
Catheads?
Tomick, No - Not Catheads which I now have. I am referring to the oversized 'Victory' name. On the model it should be no more than 60mm. The name' Victory' supplied by DeAgostini measures nearer 80mm. I thought my previous post made this clear that it is too large and I asked if it were possible to get a correct sized one anywhere else. John
PLUTO
#6 Posted : 13 February 2013 12:49:44
Plymouth57 wrote:
Hi Pluto.
Best of luck
Robin
Many thanks for that suggestion Robin. I'm glad that I am not the only one that knows the 'Victory' name supplied is oversized. I will endeavour to acquire some waterslide transfer paper and have a go at correcting the problem. I'm certain that there are some standing rigging items misssing from the instructions, when I make compare photo's of 'Victory' in Portsmouth with the completed model - but that's another issue. Thanks again. John
#7 Posted : 13 February 2013 14:22:59
PLUTO wrote:
Tomick wrote:
Catheads?
I think Toms question is around the title of your post which refers to catheads yet the topic is totaly unrelated. Blushing Blink BigGrin LOL
