 Rank: Pro  Groups: Registered
Joined: 30/08/2012 Posts: 336 Points: 857 Location: London
A little unsure. With a pin pusher, do the pins only go in as far as you push them or do you need a depth stop if you want to do that?
I'm trying to choose between the Amati and Mantua pin pushers, but don't know if either have a depth stop or of I need one.
I use this one which has a depth stop and is there if you wish to use it and is also a robust item..http://www.cornwallmodel...g/mantua_nail_fixer.html
Cheers Mr T, i'll get it ordered.
[quote=Tomick] I use this one which has a depth stop and is there if you wish to use it and is also a robust item..http://www.cornwallmodel.../mantua_nail_fixer.html[/quote] Tomick Many thanks for the advice. Have just ordered one from cmb. My existing Amati one has a very weak aluminium tube and is forever getting bent. The one you use looks a lot stronger. Kind regards Tony Happy Modelling
