33 Pages «<1516171819>»
Surprise Build Log by Mo Options
#321 Posted : 29 January 2013 22:34:22
Realy nice work there Mo, your tips are excellent so keep them coming....
Mo
#322 Posted : 31 January 2013 21:29:32
Its onwards and upwards with the masts now, trying to work out the blocks, how many and where they go, Moriaity has been a great help to me, thanks again Ian,
Just a wee note to let you see how I am doing the tying of the thread on to the blocks.
Firstly I am holding the block in a pair of reverse tweezers.
I have got the jaws of my vice open about 8 10 mm
I then slip my tweezers in to the vice, this puts extra pressure on the end holding the block, so it good and secure.
I then put some PVA Glue on to the block and thread the rope around the block tying it of with a little bit more PVA. Cant show you a picture of that, I only have 2 hands.
I have made a batch up, in no time at all. Was really worried about this task at the beginining, but as you get into it, it not to hard a job.
This is what I have done where I have two blocks hanging side by side, don't know if its the right way to do it, but it works.
Mo
Mo
Mo
#323 Posted : 31 January 2013 21:38:29
This is where I am now with the main mast, The middle one,
First the very top
two, one holed blocks hanging to the rear. and one to the front.
at the crosstrees bit, I have put 2 one holed blocks to each side, and to the rear I have put 3 one holed blocks.
To the front I have put 1 three holed block and tackle.
Mo
Mo
Mo
#324 Posted : 31 January 2013 21:42:27
At the platform at the top of the first section I have done the following.[/size
View from the front.
This is the rear view, I have put in 3 eyelets each side, but I am not sure what to hang from these eyelets,
[size=7]Mo
Mo
moriarty
#325 Posted : 31 January 2013 23:42:15
Hi there Mo, on mine I have installed double blocks. These are to take the lines which are connected to the sails to help furl them, 3 lines on each side. The plans dont show it this way but the other set I have sent you will. I sent them 2 days ago.The way you have done it will probably take the sheet and clue lines from the mainsail on the fore spar. A couple of pics fore and aft might show you this. Hope you dont mind them on your diary.
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
moriarty
#326 Posted : 31 January 2013 23:43:21
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
moriarty
#327 Posted : 01 February 2013 16:07:59
Sorry Mo I just read this again and you are on about the main mast. I aint got anything on that yet but the same rule will probably apply. You just keep working back toward the stern and install as the fitting needed comes up.BigGrin
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
Mo
#328 Posted : 01 February 2013 23:19:52
The story so far, Really getting in a tizz, about the rigging, I know I am not there yet, but with doing the masts, I am also putting on the blocks, and the blocks will have to be correct for the rigging, Moriaity has been a great help to me here, but I have decided to put a halt to the masts for now, and go back to the deck etc. This first picture I am posting, is showing the detail at the top of the bottom section of the rear mast, There is a small cleat for rope's to go through. I have done the front and Middle mast, but the drawing does not show it on the rear mast, but I am doing it anyway, because it just feels the right thing to do.
Over the weekend I am going to put the tops on the forward bulwarks, I have been avoiding this for ages, the wood is shaped to size, it just needs the final fit and glueing in place.
And finally a picture of the deck, really happy how its all turning out.
Mo
Mo
Mo
#329 Posted : 04 February 2013 23:03:54
Fitting the cappings to the bulwarks at the bow,
Capping all fitted, sanded a painted, been dreading that job, But now an even worse job, something else I have been avoiding foe ages.
The rear of the ship, I have decided to do the area under the cabin in walnut, I am going to form the cannon holes, but I will eventually put the door on closed. I think I will just give the walnut a coat of Danish Oil, think it should look ok.
Just a picture of the front end with the capping on and all sanded and painted up.
Mo
Mo
#330 Posted : 05 February 2013 22:28:21
Quality work there Mo, looking fantastic... well done...
Hans
#331 Posted : 06 February 2013 07:17:08
Some good neat and tidy building there, Mo. Following your build with interest. Well done.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
#332 Posted : 06 February 2013 07:25:29
Looks really good. Think Surprise is going to be on my wants list!!!
Tigger49
#333 Posted : 06 February 2013 09:25:09
Rank: Amateur level 2
She's looking Great Mo.
Andre
Building:
DeAgostini:
HMS Victory
HMS Surprise
Sovereign of the Seas
H.M.S Victory Cross-Section
moriarty
#334 Posted : 06 February 2013 12:00:20
Coming quite nicely Mo, remember about the belaying pins now would be a good time to sort them before you fit any guns.BigGrin
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
Mo
#335 Posted : 10 February 2013 12:50:00
Quick update where I am now, still on the back of the ship, I have been tying to get the forecastle column's to fit, the gaps between the windows are to small, I should have used a spacer the size of the columns when I was fittting the window beads. anyway a bit of filing and grinding and I have made them fit. /size]
I have a brass sheet with what I think is the gunport lid hinges, they do not look like the ones on the instruction booklet, can anyone tell me if these are the hinges it the ones on the right hand side of the sheet below.
[size=7]I would post more pictures but I think my camera is on the blink.
Mo 📷
Mo
moriarty
#336 Posted : 10 February 2013 14:24:57
They are the hinges Mo.With a lot of thought and work you could probably get them to open and close, but as they are it,s open or closed. I made my own and didnt use them so mine do both and I use them for other thingsBigGrin
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
Mo
#337 Posted : 10 February 2013 15:59:27
Thanks Iain, the firs two gunport doors I was going to do were the 2 at the rear, and I would make them closed, I think I have got my other camera to work, lets see. After filing the rear of the Captains Quarters, there is a bit of remedials to do, sand it all back flat again,
As you see above using the electric plank bender I am shaping the wood for around the window section.
Works out ok, I socked the timbers in hot water for 30 mins before bending, turned out good.
A bit of glue and the odd pin and made a start, A lot of sanding and final works to do before painting
Will report back later, Hope the pic's are ok, as I said different camera.
Mo
Mo
#338 Posted : 10 February 2013 22:12:18
Looking great Mo.. very nicely done....BigGrin
Mo
#339 Posted : 10 February 2013 22:39:07
[size=7Its coming together now at the back of the ship. Just wished I had used a spacer at the time of putting the beads in for the windows.[/size]
Looking better now, I have found the timber to go across the top of the windows is to short, I will either have to make a bit up to extend it, or ~I could put a little timber in at the centre point, Will have a look at that tomorrow.
Mo
Mo
Mo
#340 Posted : 11 February 2013 17:22:22
Making a good bit of progress on the rear of the ship now, its all coming together. I have painted all the brass and timber the same gold colour.
The columns were to long as well, and had to file to the correct length.
Really happy how it's all turning out, I now have to do the side windows in the same manner.
Mo
Mo
This page was generated in 0.207 seconds.
